Suspension & Brakes Theory, alignment, spring rates....
Help!! Megan coilovers
Old 03-01-2017, 04:28 AM
Edgar Mojica's Avatar
Default Help!! Megan coilovers
ok Idk if anybody has ask this or done this but is there any way to cut the threaded part of the bottom from my Megan coilover so I can go lower.
Old 03-02-2017, 11:14 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: Help!! Megan coilovers
Lol.
That's the shock. If you cut that, all the fluid and guts will spill out.
Old 03-02-2017, 11:20 AM
Oh ok lol I guess I have to order shorter springs to go more low then. Thanks
Old 03-02-2017, 01:12 PM
I like to party
2LEM1's Avatar
I can't even
Old 03-02-2017, 01:14 PM
Why not ?
Old 03-02-2017, 01:47 PM
B serious's Avatar
Do you have enough shock travel for shorter springs to work?
And are you sure you're adjusting them properly?
Old 03-02-2017, 01:58 PM
Hmm I don't even know. How would I figured that out I'm not really sure. Yea I'm adjusting it right because the bottom part i screw it all the way to where it won't turn any more.
Old 03-03-2017, 06:51 AM
B serious's Avatar
Then that's as low as it will go. Unless you're willing to start lowering the spring portion.
The answer to my own previous question about shock travel: No. You do NOT have enough shock travel to lower the springs or get shorter springs.
But if you don't care about how the car rides, you can definitely lower it further by modifying spring position or length.
Old 03-03-2017, 07:02 PM
redlinetuning's Avatar
?????? grammar police alert.... Did English grammar die all of a sudden? Go more low? WTF? go "LOWER".
If you want more low, then cut the ******* thing. If you want to have your car sit lower, then just lower the spring perches so there is no preload. Keep in mind the ride quality will be less than shitty.
Old 03-04-2017, 11:04 AM
I like to party
2LEM1's Avatar
Nobody has brought up extended top hats, eh?
OP is probably too cheap for those anyway.
Old 03-04-2017, 05:27 PM
B serious's Avatar
lol y'all attacking poor OP.
Extended ball joints would work to lower the car.
I assume it's low as a MF already though.
Old 03-04-2017, 07:09 PM
I like to party
2LEM1's Avatar
Going to need to see the writeup on this
Old 03-04-2017, 09:35 PM
Fish Twig
tony_2018's Avatar
You can't just spin that **** all the way down?
Old 03-09-2017, 09:30 AM
00blkSi's Avatar
Extended top hats won't allow him to go lower, it just allows for more shock travel so it's not bottoming out on the top hats.
Old 03-09-2017, 09:54 AM
I like to party
2LEM1's Avatar
It will allow him to lower the top spring perch though.
Godsrightwingx3
Suspension & Brakes
25
05-10-2013 12:06 PM
BLeSR
05-07-2010 12:33 AM
Hatchtrap
02-08-2003 05:24 PM
DRxCIVIC
11
04-22-2002 09:33 PM
mattmw88
01-29-2002 08:14 PM
Quick Reply: Help!! Megan coilovers
