Suspension & Brakes Theory, alignment, spring rates....
brake caliper
Old 05-05-2009, 05:59 PM
mullet eater's Avatar
Icon2 brake caliper
will the front brake calipers off a gsr bolt up to 91 crx si knuckles??????
Old 05-06-2009, 06:38 AM
ApexiChild's Avatar
Default Re: brake caliper
please use search.
If you do not know how to effectively use it please ask.
*Also, next time make your thread title specific, this will make it for people WHO CAN help to post.
back to your question:
No you cannot use 94-01 GSR calipers on your EF si/dx knuckle.
Remember, with your EF si/dx knuckle you cannot use any "calipers off" other honda/acura car which have 10.3' rotor or bigger.
Your options:
a) find (rare) 90-91 civic ex knuckle
it will have 10.3 inch rotor (larger than 9.4 stock si/dx)
it will have larger caliper (piston is 57mm vs 53mm)
b) buy fastbrake.com "adapter"
this will allow you to do 2 things (pick your combo):
1) use calipers from:
EF-EG-EK(ex), DA, DC = all have calipers with larger pad surface and 57mm caliper piston
or
ITR + 90-97 accord wagon + 96 prelude vtec = have even larger pad surface & piston (not sure what size)
2) use 10.3' rotors from:
or
use 11.1' rotors from
ITR, 03 CL, 96 prelude vtec, 88-89 vw corrado
HTH
fluxekhatch
03-15-2007 11:05 PM
i heart honda
10
01-31-2006 06:52 AM
. M i c h a e l
01-04-2006 01:33 PM
blundar
Suspension & Brakes
08-18-2005 08:17 AM
MAD SCIENTIST
04-19-2004 06:05 PM
Quick Reply: brake caliper
