Suspension & Brakes Theory, alignment, spring rates....
EG progress II coilovers on an EF?
Old 12-28-2011, 07:09 PM
bmxtrev's Avatar
Default EG progress II coilovers on an EF?
I found some progress II full coilovers for EG/DC chassis, but I need them for an EF. Will these fit an EF hatch? will i have to modify anything, will i not be able to drop the car as far, etc?
thanks
Old 12-28-2011, 07:42 PM
KINGVEM^^ED6's Avatar
Default Re: EG progress II coilovers on an EF?
Should fit use the eg forks
Old 12-28-2011, 07:49 PM
bmxtrev's Avatar
so i wont run into any problems as long as i swap out for EG forks? will i still be able to get some tire tuck?
Old 12-28-2011, 10:22 PM
90civic-ZC's Avatar
Not sure what the "progress 2" coilovers are but if they're a full coilover kit like you say then what "KingVem^^ed6" said is what you need to do. If it's just coilover springs then you can put them on EF shocks and still use your EF forks. I have EG coilover springs on my EF shocks that way and I personally like the set up for the price I got them. The spring rate for a EG is alittle more stiff than EF's are. As far as tire tuck, it just all depends on how low your coilovers can go and what rim size you're ridding on.
Old 12-29-2011, 06:37 AM
I said I don't want a title!
Todd00's Avatar
I would worry less about "tire tuck" and worry more about having enough suspension travel.
Old 12-29-2011, 11:45 AM
bmxtrev's Avatar
Originally Posted by solbrothers
Bro, he wants to be hella flush. Stance is everything.
I wasn't aware that I ever said that, bro.
And I'm sorry that you believe stance is everything, thats a rather poor theory. If I wanted madd tyte jdm stance I would just cut my springs. I am looking for form and function, on a budget. Thank you for your worthless post.
Old 12-29-2011, 11:50 AM
The Grumpiest
grumblemarc's Avatar
Progress CSIIs have an optimal height that they should be adjusted to. GO ahead and slam it but don't come back later saying they are crap because the shocks blew or the ride quality was shitty.
Old 12-29-2011, 12:11 PM
bmxtrev's Avatar
Thank you for your opinion, but you still have not provided any valuable information that pertains to my original post.
Old 12-29-2011, 12:49 PM
The Grumpiest
If you were the first person that ever asked this question I could understand.
https://www.google.com/search?q=eg+s...w=1656&bih=897
Old 12-29-2011, 12:51 PM
bmxtrev's Avatar
its funny, i click that link and all the google links are purple. Im looking for a solid answer.
Old 12-29-2011, 01:10 PM
The Grumpiest
Are you friggin' kidding me? The very first link says that you can use the EG forks or you can chose NOT to. Your choice.
Old 12-29-2011, 01:21 PM
bmxtrev's Avatar
But i want to know if the fact that eg shocks are longer leads to the problem of maxing out the coilovers just to lower the car to stock EF height.
Old 12-29-2011, 02:00 PM
The Grumpiest
Should have said that EXACT THING in the very first post.
Old 12-29-2011, 02:02 PM
bmxtrev's Avatar
thanks
Old 12-29-2011, 02:25 PM
The Grumpiest
This
Is no where near the same thing as this
How many posts like this one do you need to read?
Originally Posted by EFM_ookie
eg/ ek shocks are a lot longer than ef shocks making your car sit higher.
next time buy suspension thats made for your car
And if you went to the Progress site you would have found out that the kit uses a shorter shock body.
Old 12-29-2011, 02:28 PM
bmxtrev's Avatar
Half of the info I found showed that EG suspension makes the ef sit much higher, while the other half showed no problems in how low you can go. I wanted to know the case for this specific brand.
How many posts like that do i need to read? while we are asking redundant questions, are your parents related?
/thread
Old 12-29-2011, 02:32 PM
The Grumpiest
Maybe reading comprehension isn't stressed in schools anymore but I've read at least two dozen different threads and none of them seem to be conflicting.
Old 12-29-2011, 02:36 PM
bmxtrev's Avatar
Due to all the pain and suffering this seems to be causing, I'm just going to get ef f2's.
Old 12-29-2011, 02:43 PM
The Grumpiest
But wait! I have so many quotes. All saying the same things!
Originally Posted by Custom Rex
i have eg full coilovers with front forks... works great just if u go real low on the front u get less shock travel than say a tein EF setup because the shocks are taller
Originally Posted by thehatchninja
I have EG suspension in front and rear.. Integra rated H&R race springs and KYB AGX's. It's a lot higher than it was on my EG
And I'm sure if you researched you would have read this. WITH PICTURES no less!
http://ef-honda.com/ben/EFhybridsus.php
"The DA shock, for instance, is about 1.5" longer than the stock EF shock. Just for the record, this height difference is ABOVE the perch. That means that your car will be the same height regardless of what shock you run."
Originally Posted by 01-0041
Yes, the EG stuff fits on the EF! If you're going to do it you need EG front forks and Ground Control top hats. Here is why: EG shocks are roughly 1" longer than the EF shocks and the yoke portion is larger on the EG than the EF.
So you ask how I know this... I have and run EG stuff on my EF.
Originally Posted by 90_EX_Civic
the eg shock/spring well fit, but the way the suspesion is on the eg, your ef well be about half an inch to a inch higher then stock. That is if it's stock shocks/springs
Originally Posted by 4drEF
I tried putting a stock EG strut with fork on my ED and it would have raised it... a LOT. I couldn't even get the strut in there because there wasn't enough room.
Not sure on the rears though.
Old 12-29-2011, 02:46 PM
bmxtrev's Avatar
holy *****, just imagine if you would've made this your first post in this thread!
Old 12-29-2011, 02:47 PM
The Grumpiest
I would have. If the OP was more specific in what he was asking. But wait... I thought you read all of this stuff?
Linville33
10-10-2014 07:05 AM
pinks11
10-11-2008 11:07 AM
BanEL
Suspension & Brakes
07-25-2008 01:13 PM
trixr
10
12-19-2007 05:39 PM
Quick Reply: EG progress II coilovers on an EF?
