Suspension & Brakes Theory, alignment, spring rates....
Which top to used with koni yellow?
Old 02-22-2006, 07:55 AM
charlie_sohc's Avatar
Default Which top to used with koni yellow?
I was wondering which top mount would you use for the knoi yellow? stock one or which aftermarket one? for a ef9
Old 02-22-2006, 09:03 AM
CRX Lee's Avatar
Default Re: Which top to used with koni yellow? (charlie_sohc)
They are made to be used with the stock top mounts but you can use an aftermarket one like the GC mount, especially if the car is lowered quite a bit and you want to trade some extra compression stroke for some droop travel. There is a current thread here abut them.
Old 02-22-2006, 09:16 AM
#1 Super Guy
94eg!'s Avatar
Default Re: Which top to used with koni yellow? (CRX Lee)
I think you mean "trade some droop travel, for extra compression travel". I could have that backwards in my mind though. The end result is that extended upper mounts will help keep you from bottoming out your shocks on bumps...
Old 02-22-2006, 09:19 AM
Tornadom's Avatar
Ground Control, or stock should work well.
Old 02-23-2006, 05:06 AM
CRX Lee's Avatar
Default Re: Which top to used with koni yellow? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I think you mean "trade some droop travel, for extra compression travel". </TD></TR></TABLE>
I stand corrected as I meant one thing and typed it sounding the other way. I didn't make it clear which was the give and which was the get.
Give = droop travel
Get = compression travel
chinkyx90
Suspension & Brakes
03-07-2009 08:14 AM
Whytey
Northern California (Sales)
04-15-2008 11:20 AM
racekar711
Suspension & Brakes
12-02-2005 08:30 PM
cbmprelude
Suspension & Brakes
07-31-2005 07:09 PM
Quick Reply: Which top to used with koni yellow?
