Suspension & Brakes Theory, alignment, spring rates....
DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
Old 03-05-2017, 04:20 PM
  #51
Steve at Heart
Bently_Coop's Avatar
Default Re: DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
Summer is fine, my car isn't near completion. PM me when ready to make it happen. I have an 89si I already put new ball joints and bearings in, would hate to swap for DA stuff after spending what I did.
Old 03-05-2017, 04:27 PM
  #52
EE2bitsk's Avatar
what size/offset are your 949's op?
Old 08-20-2018, 08:06 PM
  #53
vc15's Avatar
Originally Posted by Oasisqc
here is the way i have done on my 91 DX
from stock 9.3'' to 11''
i keep my oem 9.3 spindle.
Use a 2007 TSX front caliper .
vw corado G60 Disk brake.
All you need to do is use a special center ring because vw disk hole is bigger. Also you put the right caliper on the left and the left on on the right ( im sure you get it )
why did i do that versus EX / DA knuckle ?
first DA knuckle change your suspension geometry and is heavier than civic one.
EX knuckle is super hard yo find in canada
Hello fellas sorry to bring this back from the dead i am intrested in doing this to my 98 ej6 dx. So i wanted to make sure that the tsx caliper will bolt on no modification other then the center ring to my dx knuckle with the corado disk and what is the caliper number? Is it 17CL16VN? Could the mini 2007 non turbo disk work ? Thanks for your inputs
Old 08-24-2018, 12:31 PM
  #54
chappys4life's Avatar
Looking at overhauling the brakes on my 94 integra. Right now its stock with stock 15's. Going to swap to type r front calipers and mini rotor. I read the dyi and just making sure i Have everything. I can still use type r pads instead of tsx right?
POWER STOP S1460 P Type-R Front caliper & bracket
POWER STOP S1556 GSR Rear caliper & bracet
PowerStop Front Rotor 2010 mini 280mm
PowetrStop Rear Rotor gsr rear
Hawk hps HB143F.680 type r front
hawk hps HB350F.496 gsr rear
Old 09-05-2018, 10:07 AM
  #55
THEhomelessONE's Avatar
Man I wish someone would sell those g60/tsx rings online. Machine shop I would go to said they don't do small jobs anymore.
Old 09-13-2018, 10:54 AM
  #56
vc15's Avatar
Hello fellas just got some 17CL16VN caliper of a tl type-s and corrado g60 rotor all mounted and brakes well but now the pads are small any other alternative thank you
Old 08-02-2020, 09:04 PM
  #57
AvianAviator's Avatar
Would I have to use B series axles if I did this swap or could I continue using my stock D series axles?
Old 11-20-2020, 06:18 PM
  #58
B00STD's Avatar
b series, you need integra 94-01 axles and hubs
carbonlaced
Suspension & Brakes
09-08-2006 09:25 AM
ek9vboi2
04-26-2005 01:29 PM
jeimport
22
10-21-2004 08:36 AM
Briman2021
04-22-2002 06:09 AM
Quick Reply: DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
