Suspension & Brakes Theory, alignment, spring rates....
d2 coilover height adjustment
Old 09-29-2008, 11:18 AM
shortbuss90's Avatar
Default d2 coilover height adjustment
if ne one can give me a pretty detailed description on how to height adjust d2 coilovers id highly appreciate it
Old 10-02-2008, 06:17 AM
Default Re: d2 coilover height adjustment (shortbuss90)
Old 10-02-2008, 09:14 AM
KaBlookie's Avatar
If you own them, there should be instructions...
Basically, you should adjust the height using the bottom mounts of the coilovers, NEVER by using the bottom spring perch. That should be tightened just enough to hold the spring in there and not allow any movement. There will be a locking collar that's screwed against the bottom mount, so loosen that and turn the mount one way or the other to raise or lower it. Also make sure that only the bottom mount is turning when you're adjusting it.
I'd recommend counting how many turns you adjust each one so you can change everything evenly left/right and front/rear (if the car is level as it is).
Old 10-02-2008, 09:38 AM
pprowler6's Avatar
Default Re: d2 coilover height adjustment (KaBlookie)
i have them...loosen the bottom lock ring and just twist the body.
mzr0r0
02-27-2008 10:08 AM
kaluwa3
Suspension & Brakes
05-13-2007 03:39 PM
2BFI
Suspension & Brakes
07-02-2006 07:34 AM
JDMlyfestyle
Suspension & Brakes
08-15-2005 08:17 PM
Quick Reply: d2 coilover height adjustment
