Suspension & Brakes Theory, alignment, spring rates....
brake pedel clicking noise and have to push in pedel far to start braking
Old 08-09-2010, 06:00 PM
swizz977's Avatar
Default brake pedel clicking noise and have to push in pedel far to start braking
ok so whenever i press the brake pedel about half way down it makes a loud cracking crunching sound and i can feel it too its really annoying what is that?
and also when i push the break pedel down it only starts to brake about halfway down.. is there anyway i can make it so it starts braking when the pedel is higher cuz it brakes when the pedel is so low..
Old 08-10-2010, 06:46 AM
swizz977's Avatar
Default Re: brake pedel clicking noise and have to push in pedel far to start braking
bumppppppppp
Old 08-10-2010, 09:40 AM
alphalanos's Avatar
Look under the dash. check pedal operation. Check the brake system for leaks and bleed the brakes correctly. If its making noise during the pedal stroke I would look at master cyl, booster, and the pivot/bolts on the pedal assembly.
swizz977
03-10-2014 03:48 PM
04es1civic
Suspension & Brakes
08-20-2011 12:04 AM
TonyBlaz
02-03-2009 11:13 AM
traxxasx
01-11-2008 06:21 PM
lv6l
01-04-2005 11:42 AM
Quick Reply: brake pedel clicking noise and have to push in pedel far to start braking
