Suspension & Brakes Theory, alignment, spring rates....
1995 honda accord tire wear HELP!
Old 02-12-2012, 02:22 PM
wrtwdtbbfl05's Avatar
Default 1995 honda accord tire wear HELP!
I need help! I have a 1995 Accord 4 door. I have horrible wear problems on my rear tires, burning through tires and am over it. I have read a few posts and stuff online and it seems like its camber, but both sides of my tires wear bad! I had a blow out saturday night at 70mph and it sucked, so i need to get this fixed ASAP. It has sprint lowering kit on it (installed before my ownership). Tires just recently started wearing bad like this as of november ish. What causes this wear on inside and outside of tires? inflation was where it should be. Is it Camber or something else? Any help would greatly be appreciated.
Old 02-12-2012, 02:30 PM
t_hickey's Avatar
Icon6 Re: 1995 honda accord tire wear HELP!
did you check your A arm bushings ?? might be the cause. usually in and out side wear is from under inflation.... but you said it was ok so i would look at the bushings.
The Grumpiest
grumblemarc's Avatar
Default Re: 1995 honda accord tire wear HELP!
When was the last time you had it aligned?
Old 02-12-2012, 02:37 PM
pressure on tire that did not blow was 38.8 and door jam says 34 and tire says 45 max. when I had new tires put on in october they said they couldnt check allignment because of an issue. Ill try and see what they said it was. could bad struts in the rear cause this wear?
Old 02-12-2012, 03:01 PM
The Grumpiest
So you have never had it aligned?
And you have bad struts?
Old 02-12-2012, 10:20 PM
theniz's Avatar
replace struts, get aligned, and drive happy
wrtwdtbbfl05
02-17-2012 03:07 AM
lamboextreme
06-17-2007 03:31 PM
SHystrdyGSRtdy
08-12-2006 09:22 PM
Thirty-Nine
11-28-2005 05:52 PM
pho iz good
Suspension & Brakes
10
02-10-2005 07:03 PM
Quick Reply: 1995 honda accord tire wear HELP!
