Brake lights inop - seatbelt/door ajar dash lights turn on when braking
Old 09-26-2016, 12:03 PM
bergercurtis's Avatar
Default Brake lights inop - seatbelt/door ajar dash lights turn on when braking
Hello all,
Curious if anyone else has experienced this before I go chasing my wiring down. When I step on the brakes, my brake lights do not turn on- but instead, the door ajar and seatbelt lights illuminate on the dashboard. The switch has to be completing the circuit, as these dash lights basically illuminate in place of the brake lights, and then go back off when the brake pedal is released. Nothing was changed wiring wise. The car sat for almost one full month in the garage, and this issue presented itself after the month of sitting. Any tips are appreciated. If I figure it out before any other feedback, I'll be sure to share.
Old 09-26-2016, 09:15 PM
acmoc's Avatar
Default Re: Brake lights inop - seatbelt/door ajar dash lights turn on when braking
look for a blown bulb
Happened to me once where my brake bulb was blown, and pressing the brake pedal illuminated all the dash lights
Old 09-27-2016, 07:15 AM
Coincidentally enough, it was just a blown fuse. The fuse visually looked good, but it was burned and open. Brake lights now function correctly. Glad I actually swapped fuses before going on my visual and moving on. Thanks though!
Old 09-27-2016, 09:50 AM
upnsmoke's Avatar
Keep an eye on it. Usually when a fuse blows it does so for a reason. If it blows again you may want to check for a wiring problem or the wrong bulb somewhere.
Old 09-29-2016, 01:51 PM
The horn and brake lights run on the same fuse. The previous owner swapped steering wheels for a sportier wheel, and only ever electrical taped the connectors for the horn button. The positive wire grounded through the steering column and popped the fuse. You're absolutely right though. It was a wiring problem.
PinoyEJ6
10-15-2007 09:21 PM
.Grimace
09-15-2005 11:23 PM
puppetmstr80
08-24-2005 12:39 PM
FullMetalJacket
12
04-29-2003 10:07 AM
Quick Reply: Brake lights inop - seatbelt/door ajar dash lights turn on when braking
