Bought a remanufactured crankshaft and there is a nick
Old 08-22-2016, 11:52 AM
Fishy_hondaman's Avatar
Default Bought a remanufactured crankshaft and there is a nick
close thread problem was solved
Old 08-22-2016, 01:43 PM
PyroProblem's Avatar
Default Re: Bought a remanufactured crankshaft and there is a nick
Pic?
Old 08-23-2016, 03:42 AM
c
Old 08-23-2016, 07:36 AM
GDD Member
slomofo's Avatar
I suspect @TomCat39 deleted my post, so i'll have to write it again.
Pic needed, but typically a barely noticeable fingernail sized groove in a crankshaft is okay and can be polished out by hand. I buy brand new Subaru EJ257/EJ251 crankshafts from the dealer at least once a month and periodically they'll have tiny gouges that I just polish out. These gouges come from bouncing around the box during shipping.
Old 08-23-2016, 09:36 AM
Hysterically Calm
TomCat39's Avatar
I was attempting to help you land on a nice post count of 1 and a quarter centuries. You posted too quickly after to see the nice number.
Also your post was rather vague and appeared sarcastic in intent.
This post you provided is much more informative and helpful. Thank you @slomofo.
Old 08-23-2016, 09:38 AM
c
Old 08-24-2016, 10:01 AM
GDD Member
slomofo's Avatar
Dude, 600 grit sandpaper is what you would use for polishing wood.
Old 08-24-2016, 06:18 PM
c
Old 08-25-2016, 04:01 PM
GDD Member
slomofo's Avatar
Not trying to knock on your mechanical skills I don't know how else to put this, but that sounds like it may have been assembly error.
600 grit will remove material and have visible scratches that you can drag your fingers across and have your nails catch on. Even if you polished it properly, you still should've gone through and mic'd each journal and/or used plastigage to see exactly where you were at as far as clearances were concerned, but from your description of the events that unfolded, it almost sounds like improper torquing as well as incorrect bearing size.
Do you use a micrometer, bore gauge, dial indicator, plastigage, or assembly lube when you assemble?
@TomCat39
Old 08-26-2016, 05:20 PM
It was below the surface
Old 08-26-2016, 10:04 PM
GDD Member
slomofo's Avatar
That little ding probably won't affect anything. If it were me, I'd remove any raised edge with a file, and just run it.
Old 08-26-2016, 10:32 PM
If it's above the surface, fix it now. If it's below the surface, let it ride.
And when I say fix it, I mean take it to get micropolished at a machine shop. Do NOT use 600 grit or anything of that nature. The journal has to be Damn near perfectly round within .0001" or else your back to square 1.
Old 08-27-2016, 06:35 AM
c
Old 08-27-2016, 09:51 AM
GDD Member
slomofo's Avatar
Doesn't look like it has any raised edge.
Pretty much, if anything is sticking above the surface, it needs fixed, but if it's all below the surface, it's fine.
Old 08-27-2016, 02:39 PM
c
Old 08-29-2016, 01:14 AM
king06's Avatar
Where did you buy it from? Nobody makes this cranks anything else you find will be "re-manufactured" which means cut and will come with matching bearings.
Old 08-29-2016, 06:07 PM
c
Old 09-03-2016, 09:14 AM
c
Old 09-03-2016, 01:24 PM
GDD Member
slomofo's Avatar
Maybe you can tell us after you run it?
Old 09-03-2016, 09:15 PM
close da thread
pensch
08-29-2005 10:52 PM
Low Kee
10-30-2001 08:05 PM
Quick Reply: Bought a remanufactured crankshaft and there is a nick
