PM6 ecu, d16a6 uncut engine wiring harness, d-series gaskets, hubcaps, etc.
Old 04-19-2008, 04:22 PM
red civic standard's Avatar
Default PM6 ecu, d16a6 uncut engine wiring harness, d-series gaskets, hubcaps, etc.
PM6 ecu is out of a 1990 RT4wd wagon. $49 shipped.
Wiring harness is out of a 1990 RT4wd d16a6 equipped wagon. This should be the same as a CRX/Civic Si harness but do your own research. The harness would definitely be good for someone doing a MPFI swap. The harness includes the resistor box and the subharness for the battery power and starter. $75 shipped.
AEM 100 PSIG SENSOR KIT. Part number AEM-30-2130-100. Details here: $167. Buy from me for $100 shipped.
Used Honda OE z6 headgasket. Used for 8 miles. $76 new. $18 shipped used.
Bare b16 TB. No sensors. $20 shipped.
OBD0 O2 sensor. Worked. $12 shipped.
Flange for making downpipe for IHI RHB5 turbo from Weir. $20 shipped.
Felpro valve cover gasket set new. $18 shipped.
d15 CRX, EF civic NEW timing belt. $14 shipped
d-series gaskets!! $3 each.
Crappy steering wheel painted black. $18 shipped
Hayden oil cooler sandwich adapter. Threads on where oil filter attaches to the block. The adapter has M20 threads on it. Fits on Honda block but does NOT work with OE oil filter. You would need to use an aftermarket filter that has a larger circumference than stock to seal properly. Better used for a Nissan or Subaru or something else with M20 threads.
$47 shipped on ebay. $29 shipped from me.
MSD pro cap 8293. Fits 94-01 GSR motor. $25 shipped.
OE Honda Civic 15" hubcaps. $40 shipped.
Civic VX 5-wires o2 sensor. Perfect for DIY wideband guys. $75 shipped.
I also have a stock EP hatch exhaust. $75 picked up or $110 shipped.
Send me a PM or email at luke.wilcox@gmail.com. I have lots of vouches on ef-honda.com and honda-tech.com and keep good feedback on my account at ebay. Username wilcoxl22.
red civic standard is offline
fleabag
06-04-2011 08:55 AM
midwesta
05-05-2006 02:58 PM
Discosteak
09-19-2004 03:02 PM
chippedrex
06-23-2004 05:37 PM
89JDMcrx
15
02-20-2003 12:42 PM
Quick Reply: PM6 ecu, d16a6 uncut engine wiring harness, d-series gaskets, hubcaps, etc.
