FS: Oil Catch Can
FS: Oil Catch Can
FOR SALE: Oil Catch Can(s)
Made of high quallity steel and stainless Aeroquip Race Hose and Pro Clamps.
PM me for priceing and/or and mods you would like to have done to yours.
If your still wondering what it does:
Your car has a crankcase breathing system known as the PCV (Positive Crankcase Ventilation) system. The purpose of this is to vent oily gases from your engine, these gases are usually fed back into your intake manifold and back into your engine but this has the effect of lowering your fuels' octane level slightly and leaves a black sludge inside your intake manifold. (Put your fingers through the throttle body and you will see what I mean). The purpose of the catch can is to trap the oil while letting the clean air continue to the engine, once the can is full you can tip it out somewhere safe. This provides longer engine life.
Re: FS: Oil Catch Can (delsol8694)
how do you drain the oil out of it and do you have to clean that filter thing inside the box like every so often or whats the deal on it....looks a lil fishy to me.....like a homemade catch can of some sort.....
ok coo....but it is homemade....correct being that my dad is an electrician isnt that an outlet box with the block plate and u just drilled in the holes for the clamps....cool *** idea and it should work....free bump for you man......
Re: FS: Oil Catch Can (TuCKiNaLL4s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuCKiNaLL4s »</TD></TR><TR><TD CLASS="quote">ok coo....but it is homemade....correct being that my dad is an electrician isnt that an outlet box with the block plate and u just drilled in the holes for the clamps....cool *** idea and it should work....free bump for you man......</TD></TR></TABLE> yep
