Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tow hook/tow eye
Old 10-15-2007, 02:06 PM
I AM WEASEL's Avatar
Default tow hook/tow eye
What are you guys using for your front and rear tow hook/eyes? are you using a tow strap or the ferrari style? please show pictures
Old 10-15-2007, 03:27 PM
117's Avatar
The bumper has seen its fair share of bumps and scrapes, so don't mind bumper. The car is a 98 Prelude. It's a track only car, so no need for turn signals. I haven't fabricated something for the rear, but I'll probably do something similar in the license plate box area.
Old 10-15-2007, 03:49 PM
Reza^'s Avatar
Default Re: (117)
basic benen tow hook works fine for me.
Old 10-15-2007, 04:24 PM
Default Re: (Reza^)
Don't most people shy away from benen and others like benen because they stick out too far? If bump drafting you could possibly put a hole in their rear bumper.
any one else have ideas for a tow eye/hook?
Old 10-15-2007, 04:29 PM
117's Avatar
That's exactly why mine is built the way it is. It's mounted directly to the bumper mounting bracket, so it's quite strong, and doesn't stick out past the bumper.
Old 10-16-2007, 06:58 AM
GBRacing's Avatar
I have soft strap attached to one of the front tow hooks and zipped-tied to the bottom of the bumper. I was afraid that if I ever get towed, it would tear my bumper but it worked like a charm. However, it doesn't look as good as I would like.
Old 10-16-2007, 07:21 AM
Another Drew's Avatar
Default Re: (GBRacing)
Soft strap here.
Old 10-16-2007, 09:51 AM
.:Made in OC:.'s Avatar
Default Re: (Another Drew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another Drew &raquo;</TD></TR><TR><TD CLASS="quote">Soft strap here.
How did you actually strap it onto the frame? Wrap around the bumper support?
Old 10-16-2007, 10:18 AM
Default Re: (.:Made in OC:.)
The strap is wrapped around 1/2" worth of aluminum bars and bolted to the bumper support. There are some washers used to space the aluminum bars away from the bumper support so that the strap doesn't get crushed.
Old 10-19-2007, 05:49 AM
Hayasa15's Avatar
dumb question where do you guys bolt the benen style hooks?
Old 10-19-2007, 06:26 AM
davidnyc's Avatar
Default Re: (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">dumb question where do you guys bolt the benen style hooks?</TD></TR></TABLE>
Mine is bolted underneath my bumper support beam. Right now it sticks out too far, but since there are three rows of holes, I am going to mount it back one more row. If that doesn't work, most likely go to some sort of soft strap technique.
Old 10-19-2007, 07:02 AM
Reza^'s Avatar
Default Re: (davidnyc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">
Old 10-19-2007, 07:20 AM
577HondaPrelude's Avatar
Default Re: (Reza^)
I use a tow strap also. That way if you bump someone it does not puncture their rear bumper cover. By the way, per the SCCA rules any tow point must be at least 2" diameter. Many of those aftermarket tow eyes are less than 2" diameter.
Old 10-19-2007, 12:45 PM
gabebauman's Avatar
Default Re: (577HondaPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">By the way, per the SCCA rules any tow point must be at least 2" diameter. Many of those aftermarket tow eyes are less than 2" diameter.</TD></TR></TABLE>
But the hardparkers get some mad style points for them at car shows.
And I bet most of the kids who have tow hooks have never even heard of SCCA or NASA.
Old 10-20-2007, 04:38 AM
Doostur's Avatar
What is SCCA or NASA?
Old 10-22-2007, 06:19 PM
BAZZ's Avatar
Default Re: (Reza^)
I have the benen tow hooks and they are good and they do not stick out to far
Old 10-26-2007, 09:09 AM
nismo1118's Avatar
Anyone running the cusco tow hooks?
http://www.jhpusa.com/catalog/...63f8c
I'm planning on running the NASA Honda Challenge
Old 10-26-2007, 09:40 AM
davidnyc's Avatar
Default Re: (nismo1118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nismo1118 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running the cusco tow hooks?
I'm planning on running the NASA Honda Challenge</TD></TR></TABLE>
You may want to look into something more substantial or use some sort of strap configuration with a strong mounting point
Old 10-27-2007, 02:58 AM
Lo-Buck EF's Avatar
Default Re: tow hook/tow eye (-DC4-)
http://www.napsusa.com/towhook.htm
-or-
http://circuithero.com/
cybersec
07-06-2017 06:22 AM
rick_rabies
16
11-27-2010 03:50 AM
vtec92lude
10-29-2004 10:26 PM
fubar
06-14-2003 12:39 PM
Tommy_Gunns
08-10-2002 09:23 PM
Quick Reply: tow hook/tow eye
