Rota Grid 15x7 ET40 wheel weight?
Does anyone know the wheel weight for a Rota Grid 15x7 ET40?
I found a weight of 13.7 pounds for an ET38 15x7 Rota Grid and 13.1 for 15x6.5 ET38
Also, I'm about to pick up some Rota Grid wheels... is the ET and width imprinted somewhere on Rota Grid wheels? I want to be sure they are actually 15x7 and not 15x6.5 before handing over the cash! (going to mount 225 45 15s and 6.5 is of no interest obviously)
Re: Rota Grid 15x7 ET40 wheel weight?
contact rota for the weight
the size, width and offset should be cast into the inside of the wheel opposite the lug holes
as an FYI, the WIDTH was NOT posted on the inside of the wheels BUT the ET38 was (seller said 15x7 with ET40 but it was actually ET38)
The width we found out from a simple measurement was actually 15x6.5" and not 7" wide (the 195 tire didn't look correct mounted on the rim which made us suspect it was only 6.5" wide instead of 7" wide so we did not buy them)
Ridin Dirty in Cali
No mistaken information will be passed on if you call the horses mouth.
http://www.rotawheels.com/contactus.shtml
yes, that is all well and good but in this case the MFR had several options for the same wheel and I managed to find out BEFORE paying that the wheels were actually the apparently more common 6.5" wide ones instead of the 7" wide ones (were advertised as 7" wide when they were not)
Both the 6.5 and 7" wide version were available in ET38 so even the embossed ET38 was not a tell-all in this case!
Ridin Dirty in Cali
Been there before.
yup, I'm guessing someone was in line behind me who doesn't care that they are only 6.5" and so it goes...
H-T Order of Merit
People sometimes make the exact same mistake with the wheel diameter.
civicrr
19
09-09-2002 11:00 AM
Chugger
01-24-2002 01:03 AM
