Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Crower's New 63412 B Series VTEC Race Core cams?
Old 04-20-2002, 01:43 PM
InfamousRS's Avatar
Default Crower's New 63412 B Series VTEC Race Core cams?
Would these cams be a good choice with a LS/Vtec setup w/CTR pistons(12.02:1 CR in LS block with B16 head)? Would they be streetable?
Hear is what Crower says about the cam:
Crower is pleased to introduce a new high performance core for the twin cam B series VTEC engine platform. This new core features bigger secondary and primary lobes for unlimited spec and the ability to run outer lobes only, grinding away the mid lobe. The fact that Crower grinds the cams in house gives you the opportunity to mix and match profiles for your particular application. Other possibilities are bigger idle lobes for increased performance on the bottom end, through the switchover point and beyond 10,000 rpm on the big mid lobe. This core is for serious race applications. Prices start at $750 for catalog grinds listed below, and $850 for custom cams with outer lobes only.
For specs: http://www.crower.com/cat/import/honda/camshafts.shtml
What do you guy think?
Old 05-05-2002, 04:26 PM
Halo's Avatar
Default Re: Crower's New 63412 B Series VTEC Race Core cams? (BLK94RS)
I am looking at getting these also, however if you check out the Crower site the 63402 has identical specs to the 63412 and yet the "race" cores are $100 more. I emailed Brian, so let's see what he says
Old 05-07-2002, 06:02 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: Crower's New 63412 B Series VTEC Race Core cams? (InfamousRS)
PLEASE make sure to check ALL clearances, even lock in the VTEC rockers.
Racewerkz
11
12-27-2010 09:27 AM
crawlin
06-08-2007 03:49 PM
nutsdc2
07-21-2005 01:50 AM
JunIntegra
05-18-2003 06:52 PM
Quick Reply: Crower's New 63412 B Series VTEC Race Core cams?
