Valve Cover Paint Help (Best Paint?)
Old 05-10-2009, 11:12 AM
callmechad's Avatar
Default Valve Cover Paint Help (Best Paint?)
im as the topic states. im currently about to paint my valve cover.
what is the best stuff to get that holds its color and with stands the heat?
i dont want to spend toooo much so a list of good paints to use were to get it and how much would be great.!! im willing to post pictures up after im done :D
Old 05-10-2009, 12:11 PM
callmechad's Avatar
Default Re: Valve Cover Paint Help (Best Paint?)
13 views and no one can help me?
Old 05-10-2009, 03:43 PM
timmybilt's Avatar
i have used everything. krylon, duplicolor, caliper paint, valspar, rustoleom..... the list goes on. i never had a problem with any of those except one time i did a white one with duplicolor and over time it yellowed but other than that i think your safe to use pretty much any kind of paint.
Old 05-10-2009, 04:44 PM
INTEGRA TYPE-XI's Avatar
Use VHT wrinkle paint Sp-201 red or SP-204 black then cook in the oven. Dont forget to change head/spark plug gasket .
Old 05-10-2009, 06:39 PM
callmechad's Avatar
cook it in the oven? wtf? could you clarify that lol.. and i think im ganna go with a blue color. and were can i get the VHT wrinkle paint Sp-201 red or SP-204 black?
Old 05-10-2009, 08:12 PM
callmechad's Avatar
bump before i go to sleep!
Old 05-10-2009, 08:52 PM
dc2teg06's Avatar
I've tried the Duplicolor Metal Cast paints on mine. I used the Metalcast Ground Coat which is like a metallic silver primer, then I used the Anodized Purple color for the base. For the clear I shot it with actual PPG clear from a gun. Once the clear hardened it felt very durable, and looked pretty legit.
Old 05-10-2009, 10:04 PM
TypeRMOBBiN209's Avatar
you can use any kinda of paint really just the key is use a high heat primer...i usually just use duplicolor high heat primer and paint with any kind of paint
Old 05-11-2009, 08:56 AM
dreamreaperx's Avatar
you don't really need high heat primer...i have done 4 valve covers, and not one had primer on it...they have held up for almost a year without any fading bubbling or any chipping...just make sure the valve cover is sanded smooth, and shoot with whatever you want..i shot base on direct metal with clear on top of that and it looks perfect
Old 05-11-2009, 04:30 PM
callmechad's Avatar
what kind of sand paper would you reccomend? since now i know any paint will work. but now i have a really good idea what i wanna do.
Old 05-11-2009, 06:13 PM
well that depends on what kind of paint you are goin to use...for a wrinkle finish paint doesnt really matter what sand paper you leave it at...for a bc/cc i like leaving it at somewhere between 400-600
Old 05-14-2009, 02:21 PM
bubbaparks2121's Avatar
Or you can get it powdercoated. I only say that cause ive done a few.
Old 05-14-2009, 03:58 PM
callmechad's Avatar
powder coated?
Old 05-15-2009, 02:04 PM
Elwuudz's Avatar
MTNMTN Montana Spray Paint is the toughest **** available or real auto paint works nice too, primer, base-coat, clear-coat and some love wet sanding buffing etc...
Old 05-15-2009, 03:12 PM
spreen honda's Avatar
have it powder coated,,,,, ( don't paint it )
Old 05-15-2009, 03:38 PM
callmechad's Avatar
ok how do i powder coat it? explain pls ;o
Old 05-15-2009, 04:23 PM
gsrauto98's Avatar
Your best bet to get it powdercoated is to take it some place in your area that does powdercoating. Cant really powdercoat it yourself unless you have a gun, the powder, and an oven to bake it in. It will hold up a lot better than just spray paint.
Old 05-16-2009, 12:10 PM
callmechad's Avatar
how much will that cost do have that done?
Old 05-16-2009, 12:31 PM
maddog20's Avatar
google trgcoating
Old 05-17-2009, 05:16 PM
We charged $40.
Old 05-17-2009, 08:11 PM
dc2teg06's Avatar
Here's how it turned out:
Old 05-19-2009, 06:23 AM
DB8_LSVTEC's Avatar
you honestly don't need that high heat BS. i just hit mine with primer and the 96 cent cans at walmart. than i sprayed duplicolor clear FX for the glitter effect than i threw some left over model car paint on it. than some more clear FX and clear. =] its been about 2 months and its still perfect.
Old 05-19-2009, 03:12 PM
bluenc-87's Avatar
Thinking about a purple valve cover too...diff looks
lilboxx
36
04-14-2012 09:45 PM
highliner82
18
12-07-2010 05:50 PM
-=ZAK=-
01-15-2009 07:42 PM
b0mb5
08-24-2008 08:16 PM
Honda97
10
11-14-2004 06:31 PM
Quick Reply: Valve Cover Paint Help (Best Paint?)
