Powder coating brake calipers
I have a powdercoating kit and I want to start powdering my friends & I's brake calipers!!! Does any1 have any tips, info, or anything good to say before I try to do this on an IMPORTANT PART OF OUR CARS??????!!!!!!!!!!!!!
Re: Powder coating brake calipers
Is this your first time powdercoating??
Well the caliper has to be fully taken apart. Seals and piston removed.
If you have never powder coated before those are not good first parts. Go with something easy to start off.
official honda whore
just make sure they are cleaned, no need to take them all apart as the seals are meant to take the heat anyways
I would like to sand blast before I clean them to make sure it flows out really nicely! But for the most part no issues other then taping and pluging holes & seals before blasting and cleaning?????????
Take them completely apart for 2 reasons:
I suggest soaking them in a 1:1 solution of simple green concentrate and water for about 6 to 8 hrs (depending on how they look) after you take them apart.
Once they dry (compressed air is your friend here) give them a light blasting to etch the surface. It'll allow for better powder adhesion which is important for something like calipers. Cover the mounting areas with duct tape so you don't blast those areas. Plug all holes and mask all threads.
Mask off ALL of the mounting surfaces so they don't get coated. I also suggest adding a clear coat. If the finish is matte, just use a satin clear to add to the protection of the coating.
Good luck,
Steve
- No chance of grease leaking while curing
- No chance of damaging the seals during blasting and coating.
Good luck,
Steve
OK COOL THANKS!!! I plan on doing the calipers in the same color REDwith a high gloss clear as the vc in the picture above!!!
Now, how do I take the calipers apart?????????????????
You need to remove all the seals and grease fittings as well as the piston and boot. Most OEM calipers are 1 piece so nothing to do there (not like 2 piece brembos).
With the caliper removed from the car, pull away the dust boot to expose the piston. With the dust boot removed, place a block of wood between the piston and caliper. Making sure your hands are totally clear of the piston, use a compressor and air gun to slowly pressurize the caliper via the brake line port. This will force out the piston violently (MAKE SURE YOUR HANDS ARE CLEAR).
Check it over, make sure it's clean and such. If so, bag and tag it for re-use. Do the same for all the other fittings.
Then reverse and repeat for rebuild. Make sure you grease up the cylinder and the boots correctly and completely when you rebuild.
Steve
Steve
I have 2 racks!!! Im going strip a place on the rack. but usally we just run the ground cable up under the rack and hook it to whatever we are coating
You can ground directly on the part when it comes to valve covers. I used to hang calipers so no problem there.
*Edit - Pics of a completely disassembled caliper (2pc however from a G37) already coated.
Steve
Steve
Steve
Steve
Your calipers on the G37 look amazing btw, my favorite color!
Looking good! Get some pics of when they're on the car!
Location: Between the hills of Downtown LA and Pasadena
After my calipers wre coated I took them to the local auto parts store and they replaced the seals and reassembled both calipers for 15$.
GSRcivicGSR
04-30-2006 11:30 AM
