mixed opinions..what filler should I use?
Old 11-03-2010, 08:18 PM
OMG it'Z McFLY!
markD.'s Avatar
Default mixed opinions..what filler should I use?
currently shaving my engine bay. every hole and seam has been welded and ground down. should I skim it with evercoat rage extreme or evercoat metal glaze. should it be applied to bare metal? thanks in advance.
Old 11-04-2010, 07:41 AM
Psychoteen101's Avatar
Default Re: mixed opinions..what filler should I use?
I used evercoat rage extreme. First i spray epoxy primer, them skim coated with the filler.
Old 11-04-2010, 10:46 PM
gorillafart's Avatar
u can go to metal, use the Rage, then epoxy and paint...
or you can epoxy it, then use the Rage, then paint
metal glaze i would not use. doesnt have the thickness to shave an engine back.
Old 11-05-2010, 02:42 PM
OMG it'Z McFLY!
markD.'s Avatar
wordd. the only reason i said metal glaze is because i welded and ground everything down and there isnt that much to "skim" over. but i guess ill go with the rage to be safe..
Old 11-26-2010, 01:43 PM
Charlie Moua's Avatar
what do you guys mean by "epoxy" ?
Old 11-26-2010, 02:09 PM
in the paint world, epoxy is a paint that refers to the first coat of that covers the bare metal, which aids in adhesion, and corrosion protection. its the best product that attempts to mimic factory E-coats from car manufactures.
Charlie Moua
Paint and Body
07-23-2014 05:13 AM
matmcg
Paint and Body
18
03-23-2008 09:28 AM
CompanyFlow
09-07-2005 07:41 PM
zseeanz
11
12-13-2002 08:59 PM
eh-D
08-05-2002 11:30 AM
Quick Reply: mixed opinions..what filler should I use?
