DIY paint not shining??
Old 08-13-2011, 07:06 PM
jtran1993's Avatar
Default DIY paint not shining??
so i decided upon DIY milano red on my CTR grille.
these are the steps i followed but i didn't get that smooth shine like the rest of the HT members got on here =(
1. sanded down with 800 grit paper
2. sprayed 2 layers of primer
3. 4-5 coats of main duplicolor paint
4. 4 coats of duplicolor clearcoat (before last coat, i sanded it down with 1500 grit paper)
5. use Turtle Wax Premium Grade Rubbing Compound
yet i have a dull non-smooth finish without the slightest shine texture.
should i use turtle wax polishing compound or would that be too harsh on my rattle can clearcoat?
Old 08-13-2011, 07:24 PM
jtran1993's Avatar
Default Re: DIY paint not shining??
im thinking of trying Meguiar's Ultimate Compound, any opinions?
Old 08-13-2011, 11:06 PM
Civic-Kids's Avatar
wait a week before polish
Old 08-14-2011, 10:02 AM
97sohc_d00d's Avatar
yeah you cant buff or polish anything until the paint has cured...it dries in no time but the cure time is a little longer
Old 08-14-2011, 07:50 PM
AztecEGhatch's Avatar
you shouldnt have sanded until after you were done painting.
primer
base
clear
-let cure- then,
wetsand and polish (rubing compound)
Old 08-17-2011, 01:03 PM
(. )( .)'s Avatar
primer
base
clear
-let cure- then,
very correct, after your done clearing, let it dry for 2 weeks. than wetsand, rubbing compound, polishing compound, swirlx, than wax. it'll look sick
Old 08-18-2011, 07:08 AM
No Jodas
ShinsenTuner's Avatar
How's your technique of laying clear? I usually lay two thin "rough" coats and then lay a thick layer to fill in the crevices and also create a nice shiny layer.
Let cure and wet sand, buff with compound, polish, and wax.
Old 08-21-2011, 07:04 PM
00blksicivic's Avatar
how long did you wait between coats, try to post up pics
Old 08-22-2011, 11:20 AM
89hatchySI's Avatar
What I would do is sand again with some 800 or 1000 wet just so the clear will grab and re clear it. Just don't get to crazy on the sanding so u don't burn into the base coat ..
Let it cure .
** depending on the clear quality u might not have to wet sand and polish to get it to really shine just some wax **
Also make sure ur not using semi gloss clear LOL...
Old 08-22-2011, 05:20 PM
ej6sir-t's Avatar
^x2
toojdmforschool
Paint and Body
10
02-12-2009 08:52 AM
firstgenrex
09-12-2003 08:49 PM
zseeanz
11
12-13-2002 08:59 PM
cracker099
11-30-2002 11:14 PM
unltdacc12
10-19-2002 11:28 PM
Quick Reply: DIY paint not shining??
