Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
element. airbag system reset
Old 07-14-2006, 06:58 AM
marcin's Avatar
Default element. airbag system reset
i had to move some thing that required taking out the front pass seat. I replaced the seat when i was done but since then the air bag light is on. just wondering if you guys know of a way to reset the system?
thankyou
m.
Old 07-14-2006, 07:43 AM
In a Junkyard near you.
Ross 2.0's Avatar
Default Re: element. airbag system reset (marcin)
To erase the DTC(s) from the SRS unit, use the HDS, or the following procedure.
Make sure the ignition switch is OFF.
Connect the SCS service connector (A) to the yellow MES connector (2P) (B). Do not use a jumper wire.
Turn the ignition switch ON (II).
The SRS indicator will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector (2P) within 4 seconds after the indicator goes off.
The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector (2P) within 4 seconds after the indicator comes on.
When the SRS indicator goes off, remove the SCS service connector from the MES connector (2P) within 4 seconds.
The SRS indicator blinks two times, indicating that the memory has been erased.
Turn the ignition switch OFF, and wait for 10 seconds.
Turn the ignition switch ON (II) again. If the SRS indicator comes on for 6 seconds, and then goes off, the system is OK.
(the connector is the yellow two pin in the drivers fusebox)
Old 07-18-2006, 05:07 AM
marcin's Avatar
Default Re: element. airbag system reset (MooGoCow3)
thankyou, i will give it a try.
marcin.
Old 07-19-2006, 04:19 PM
Jason's Avatar
to save yourself the hassle, next time disconnect the battery before doing anything that you think might trip the computer...
Smok3o3
02-22-2011 05:53 PM
fastfu
11-14-2005 04:31 AM
SaberSix
Acura TL, RL & ZDX
07-09-2004 02:41 PM
rkonfire
05-27-2004 08:11 AM
Mrivera21
05-28-2003 03:03 PM
Quick Reply: element. airbag system reset
