Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CR-V problem
Old 02-08-2007, 03:03 AM
Decatur's Avatar
Default CR-V problem
Hi all!I need a technical suggestion regarding a problem with 1998 Honda CR-V,4WD,Auto,4 cyl.When drive the car ,steering pulls due to slipping differential and there is noise particularly on turning.I had a mechanic look at it who said it was the differential slipping and not the gearbox.My question is:What does that means?Is it possible to disconnect the front axcels,and keep driving as a RWD?Thank's in advance for paying attention,George.
Old 02-08-2007, 04:01 AM
golf's Avatar
Default Re: CR-V problem (Decatur)
I'm not sure if I follow you.
Is it possible the noise is a bad cv joint ?
You wouldn't be able to disengage the front axles since it's full time front wheel drive.
Old 02-08-2007, 08:05 AM
Decatur's Avatar
Default Re: CR-V problem (golf)
Actualy i haven't see the vehicle.This is everything i know.The guy just told me "there is a banging noise when driving and louder banging noise when turning, noise and steering pull came on suddenly without warning, vehicle not driven since.
"He is not a specialist,so the info is limited...
Old 02-09-2007, 06:10 AM
In a Junkyard near you.
Ross 2.0's Avatar
as in the rear differential? You need to change the fluid in it with Honda "Dual Pump" fluid. That will eliminate the noise. This is a very common maintenance issue.
It can not be driven as a RWD due to it's configuration.
Murilo EJ1
Transmission & Drivetrain
01-16-2019 12:30 PM
burntkookie
01-19-2010 06:09 PM
qhondak
10-06-2009 10:17 PM
Decatur
02-08-2007 08:53 AM
sporkcrx
Acura TL, RL & ZDX
18
10-28-2004 05:59 PM
Quick Reply: CR-V problem
