Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Clicking noise when make turn with the turning signals on ..
Old 11-14-2012, 10:28 AM
ajun217's Avatar
Default Clicking noise when make turn with the turning signals on ..
My new 2012 Pilot EX-L is now over 1000KM on it. I just started to notice that it makes several loud click noises when I making a turn with the turning signals on. This is not the normal turning signal's relay click, when I rotate the steering wheel making turn, there are other several laud click sound, for example 1/8 circle I hear once, then 1/4 circle another one.. It sounds like the turning signal is making that noise because when the turning signal is off I couldn't hear such click when making turns.
What is this clicking noise and is this also normal? thanks
Old 11-14-2012, 02:46 PM
salaamq's Avatar
Default Re: Clicking noise when make turn with the turning signals on ..
It sounds like the turn signal return switch is bad...
Old 11-10-2014, 04:28 PM
Tesla300's Avatar
ajun217 Did you ever get this problem solved? I'm having the same problem.
Old 11-12-2014, 08:25 AM
GDD Member
slomofo's Avatar
The most common problem is the coupling located at the bottom of the steering shaft.
If you remove your floor mat, then pull the carpet back you'll expose a plastic boot at the bottom of the steering shaft. Remove this boot and you'll see a coupling joint secured with two 10mm bolts. Loosen the 10mm bolts, slide the coupling downwards, but not all the way off. Apply generous amounts of grease to the splines on the shaft, slide the coupling back up into position, secure it down by tightening the 10mm bolt, apply some more grease to the joint itself, then reattach the boot, put the carpet back, and see if that solved your issue.
yesSiReK
11
11-21-2006 11:20 AM
pepper2
08-22-2006 09:41 PM
wowowee
10-20-2005 07:39 AM
Quick Reply: Clicking noise when make turn with the turning signals on ..
