Acura Mdx error code 1399 i want to blow this car up
New User
82k mile 01 acura mdx. we are the original owners and i swear i want to torch this car. did the timing belt, plugs, egr tube cleaning and i still have that error code 1399 then 302;300;303;304 follows it. i find that hard to believe that all 4 cylinders are misfiring. i already replaced the battery yesterday and checked the grounds. has anyone else ever had error code 1399 which allegedly means general misfire? i checked the timing and it is dead on. the only thing else i can think off is replacing my coilpacks which i'm doing tomorrow, or ignitor or a crank angle sensor went bad. any help would be appreciated.
thanks,
sid
thanks,
sid
Re: Acura Mdx error code 1399 i want to blow this car up (sidwin)
i had a 02 Mdx...got a misfire code onetime from bad gas, i just cleared it and it went away...usually when you get one code it trips the center diff light, and the truck runs in a different mode, which could lead to more codes and it driving unusual...good luck with it
Usually what happens is one cylinder is misfiring, you'll start with a random misfire which is the code 1399 that you're getting. Then if you monitor the data list the cylinder w/ the true misfire can be recognized. From there it's not uncommon to get a misfire from mulitple cylinders. You need to clear everything and let the engine idle and see which cylinder is detected first, then most likely it's going to be the injector for that cylinder (rarely have I seen a coil pack go bad on an MDX). It's hard to replace just 1 injector though, when removing the fuel rail, even being extremely careful, you're bound to break more than one, be prepared to replace all 3 on the bank that contains your cylinder that's misfiring.
Re: Acura Mdx error code 1399 i want to blow this car up (LeftCorner)
[IMG][/IMG] IMG]http://i82.photobucket.com/albums/j262/jdm_bones_2006/Bigassbump.jpg[/IMG]
Re: Acura Mdx error code 1399 i want to blow this car up (JUNE_BUG)
In a Junkyard near you.
don't even bothor trying to upload that picture...
nobody has been owned here exept you owning yourself with that picture. haha
We don't do that kind of thing here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNE_BUG »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
here you go fixed...
sidwin
Acura TL, RL & ZDX
07-21-2006 10:00 PM
