Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey Hum in rear end.
Old 10-05-2011, 05:34 AM
jtmcmahan10's Avatar
Default Odyssey Hum in rear end.
08 Odyssey EXL 55K on it.
When I get up to 40 mph, I get a fairly loud groan or hum out of the rear end. I rotated tires and even worked in a 5th to rule out tire noise. I'm thinking wheel bearings. Is this common? Anything else to check? Are rear bearings warrantied under powertrain?
Old 11-23-2011, 06:41 AM
HNDA_4SHOOR's Avatar
Default Re: Odyssey Hum in rear end.
feel the tires and make sure there is no uneven wear. Rotate it again and see if noise is still from the back. If it is then it's not your tires
Old 11-24-2011, 03:02 PM
Schmuck's Avatar
I'm not sure how common it is but my 06 EX-L needed a left rear wheel bearing at 130K. I just replaced both rears at the same time. It's not too difficult but I'm an automotive technician. The price of the factory bearing isn't bad and the quality is great.
Romanx
03-14-2010 12:59 AM
BiG_DeE
04-02-2008 09:07 PM
jjr_99prelude
07-16-2007 05:55 PM
stavros007
02-05-2006 11:48 AM
jdmstreethatch
08-11-2004 05:36 AM
Quick Reply: Odyssey Hum in rear end.
