Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1999 Honda CRV flashing check engine light with 25PSI in cylinder #1
Old 03-20-2006, 01:42 PM
zthonda's Avatar
Default 1999 Honda CRV flashing check engine light with 25PSI in cylinder #1
I have 1999 Honda CRV have flashing check engine light. Checked compression on cylinder #1 it only have 25PSI. the car have 120k. Any one can help me what option I have with engine? I went a place they told me they can rebuild top of the engine for $1000. Is this a good thing to do with the car. Thanks a lot for any help.
Old 03-23-2006, 05:13 PM
In a Junkyard near you.
Ross 2.0's Avatar
Honda has a service bulliten for this. The exhaust valves in #1 have recessed into the head causing them not to close propperly.
You need to replace the head and valves.
If you wish to sell it let me know.
Old 03-23-2006, 06:49 PM
zthonda's Avatar
Default Re: (MooGoCow3)
Thanks MooGoCow3. Where can I access this Bulletin? Does Honda provide fix on the problem?
Old 03-25-2006, 04:37 PM
alpine_hikr's Avatar
Default Re: (zthonda)
yeah the fix is to replace the head and valves.
Old 03-30-2006, 10:53 AM
gotboostedvr6's Avatar
not too cut throats but im in nj and in the markett to buy a vehical like what you have please contact me via private message or email me at gotboostedeg@gmail.com
cash in hand
Old 03-31-2006, 06:59 AM
Stripped Honda's Avatar
Default Re: (gotboostedvr6)
i have done a few of these at the shop and have found that you can usually just do a valve job and replace 1 or 2 valves and you will be fine ... i have never changed the head ...
miaozer
02-04-2015 06:32 AM
alldrew
11-05-2008 06:22 AM
hckyNhonda29
01-18-2007 07:27 PM
Quick Reply: 1999 Honda CRV flashing check engine light with 25PSI in cylinder #1
