Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
06 pilot-power window relay location
Old 06-04-2012, 12:13 PM
matt846's Avatar
Default 06 pilot-power window relay location
06 pilot none of the power windows work. checked the fuses for each window on the pass. side fuse box. checked the power window motor fuse under hood. disconnected battery. nothing worked (lock is off). I am thinking the power window relay? I just don't know where it is except for under the dash. Help. Pictures, links, details of where to look for it.
Old 06-04-2012, 02:50 PM
matt846's Avatar
Default Re: 06 pilot-power window relay location
anyone have a 06 pilot service manual. a picture of where the power window relay is located is all I need
Old 06-04-2012, 10:44 PM
Qfactor's Avatar
is located on the on the passengers side multiplex control unit, square white box.
Old 06-05-2012, 10:21 AM
matt846's Avatar
thanks. I just purchased the passenger side multiplex control unit and the relay for the power windows to be save.
Old 01-27-2020, 04:13 PM
Bobby Gafford's Avatar
Guys,
I've replaced the actuator/motor, tried 3 proven master switches, fixed a poor battery ground, changed the good fuses 40 in the main engine box and 10amp in th passenger box, bypassed the main driver window motor controller, traced and tested connections to the wires, replaced a good bulb in the driver door... Can't find this "relay" switch on the passenger fuse box on any diagrams I've downloaded... Are you talking about a relay like the small ones you see in the main fuse box for acc, pw, etc?
Driver window control unit
Master switch
Proving/bypassing
Locating 12v and proving motor/switch functionality...
The driver window is on track, and well lubed...
Why does it only go down an inch at a time? Up is fine now after fixing the ground from battery. Where is this relay on the passenger multiplex and does it possibly affect the driver window?
Stingroo
09-03-2015 07:02 PM
crxpwr1
06-02-2013 02:25 PM
419integra
07-16-2012 01:29 PM
gaccord00
11-09-2004 08:00 PM
Quick Reply: 06 pilot-power window relay location
