1994 Civic Si hatchback black
1994 Honda Civic Si hatchback
Color: black
Title: clean, in hand (Carfax is also clean)
Mileage: 176,000 on the body, Motor mileage unkown
ENGINE:
JDM B16 SirII motor
GSR transmission
USDM ITR Intake manifold
B16 64mm throttle body (bored by Maxbore.com)
PasswordJDM.com intake manifold gasket
PasswordJDM hardened shift linkage bushing kit
Odyssey PC 680 battery
C&R aluminum radiator
Samco B16 black radiator hoses
Fastline Performance stainless steel clutch line
NGK spark plug wires
P28 ECU chipped w/ crome
95 GSR fuel pump
Password JDM carbon fiber power chamber intake
Mugen brake, power steering, and clutch fluid reservoir covers
MEGAN 4-1 header w/ 2.5" collector
Carsounds 2.5" High Flow catalytic converter
Apexi World Sport Exhaust
BRAKES and SUSPENSION:
GSR 4-lug brake conversion
Integra RS 40/40 proportioning valve
91 Civic EX 4-door 15/16 brake master cylinder
Silk Road RMA8 coilovers
ITR rear lower control arms
92-95 Si front swaybar
GSR rear swaybar
Mugen front upper strut tower bar
Mugen rear upper strut tower bar
Earl's stainless steel brake lines
Endless hi-performance brake fluid
WHEELS and TIRES:
LS Mesh wheels
Stock Michelin tires
1 Integra "Sunflower" wheel (used for a spare)
INTERIOR:
USDM ITR front seats
Custom upholstered door panel inserts, black tweed w/ red stitching
Custom suede arm rest w/ red stitching
USDM ITR red stitched shift boot
MOMO Monte Carlo steering wheel
JDM EG6 Horn button
MOMO hub adapter
USDM Optional audio console
USDM Optional arm rest
JDM EG6 amber defroster switch
JDM EG6 amber clock
JDM EG6 amber climate control
JDM cup holder/tray
JDM EG6 Hatchback fog light switch
USDM Power Window/Door lock conversion
USDM EX black door panels
Mugen shift ****
Mugen pedals
J's Racing C-pillar bar
PasswordJDM H4H Hyper white headlight bulbs
PasswordJDM fog light wire harness
I.C.E.
Kenwood Excelon VZ 907 head unit
MB Quarts 1" tweeters
Rockford Fosgate P152S Seperates (front)
Rockford Fosgate P152S Seperates (rear)
EXTERIOR:
JDM EG6 SiRII thin side moldings
JDM EG6 SiRII front lip spoiler
JDM EG6 SiRII rear one piece metal spoiler
JDM EG6 SiRII Stanley headlights
JDM EG6 SiRII Stanley corner lights
JDM EG6 SiRII tail lights
JDM EG6 side marker lights
JDM EG6 SiR yellow Stanley fog lights
92-95 Civic HB rear wiper plug
Spoon/Vision carbon fiber type MC mirrors
Other parts that have been replaced in the past 2 years (replaced with Genuine Honda parts):
Valve cover gasket
Spark plug tube seals
4 inner valve cover grommets
Spark plugs
94-97 Del Sol DOHC distributor cap + rotor
GSR distributor o-ring
GSR cam end seal
GSR VTEC solenoid gasket
O2 sensor
Drivers inner CV boot
Power steering pump belt
Fuel filter
Oil pan gasket
New remanufactured Honda starter
ITR throttle body re-build kit (MAP o-ring, MAP screws (2), Idle adjust screw and o-ring, Throttle body gasket)
ITR throttle cable and bracket
Transmission shift shaft seal, axle seals, and throw out bearing
Honda OEM clutch master cylinder
New Drivers door sash
New left and Right outer door belt moldings
Rear trunk seal
The stock steering wheel, rear window wiper and A/C will be sold with the car.
The windshield has a small crack where the rear view mirror mounts to the windshield, and it has a few dings. The paint on the roof is hazing (a common problem with these cars). Numerous door dings, rock chips (what do you expect from a 14 year old car), nothing major. The rear bumper has some scratches. All four wheels have some curb rash.
All this car needs is a paint job, new windshield, and a nice set of wheels. This used to be my daily driver, so I can vouch for it's reliability. NO TRADES!!!!!
Please no tire kickers or joy riders. Test drives will be under my conditions at a location of my choosing.
$7500
Modified by MENACEteg at 1:59 AM 10/2/2008
Color: black
ENGINE:
JDM B16 SirII motor
GSR transmission
95 GSR fuel pump
GSR rear swaybar
WHEELS and TIRES:
LS Mesh wheels
INTERIOR:
JDM EG6 Horn button
MOMO hub adapter
JDM EG6 amber clock
JDM cup holder/tray
Mugen shift ****
Mugen pedals
I.C.E.
EXTERIOR:
Valve cover gasket
Spark plugs
GSR cam end seal
O2 sensor
Fuel filter
Oil pan gasket
Rear trunk seal
$7500
Re: 1994 Civic Si hatchback black (MENACEteg)
I can vouch for Alexis! Super legit guy with the cleanest parts around.
This guy doesn't cut any corners with his builds!
This eg is worth every penny!
Re: 1994 Civic Si hatchback black (djnakturnyl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jummpmann »</TD></TR><TR><TD CLASS="quote">those door pannels are ballin! </TD></TR></TABLE>
Thats FOR SURE
Clean EG
Thats FOR SURE
Clean EG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1-t »</TD></TR><TR><TD CLASS="quote">bump for a 100% legit dude
bump for you
bump for you
Exactly what I've been looking for!!!
A clean *** black Si.
So hard to find!
Unfortunately I'm striking right now at boeing and don't have money right now. BUT, we're going back to work hopefully on monday and we're getting a nice bonus so I might be able to buy this off you within a week or two if you still have it.
Are you willing to lower the price if you remove parts?
GL with the sale for your sake, but for my sake I hope you still have it when I come up with the money.
So hard to find!
Re: 1994 Civic Si hatchback black (Numba1 B Series)
happy with my current ride, but that is one nice hatch. a slam and some nicer wheels and it'd be fresh to death.
