94 OBD1 LS engine **COMPLETE!!**
i have a 100% COMPLETE obd1 Honda B18B1 LS engine for sale. this was pulled by me from my own 1994 Integra RS. this engine was running strong until the minute i pulled it out. I will provide a copy of the title of the car with the motor sale, so we know all is legit. i also have a pile of reciepts to go along with it.
this engine is more than a standard longblock, and is SWAP IN READY. in addition to the longblock, it will come with:
intake manifold (including ALL sensors, throttle body, fuel rail, injectors, fuel pressure reg)
exhaust manifold (including downpipe WITH O2 SENSOR)
AC compressor (works well)
power steering pump
alternator
starter
distributor (only 2 yrs old, along with cap and rotor)
wiring harness (has a few cuts)
original obd1 ECU computer(its for an AUTO, if you want it)
all required pulleys and belts
service done WITHIN THE LAST 500 MILES:
timing belt
water pump
head gasket
cylinder head was machined, pressure tested, and painted
**while the head was off, i checked the block deck and made sure it was within service limits**
i removed the valves and media-blasted them
brand new valve stem seals
IM gasket
EM gasket
oil pan gasket
upper radiator hose
**i also have the original auto transmission that was in the car, and it is still attatched to the engine. if you want the trans as well, let me know and we can work out a package price, if not ill separate them. trans runs well and just had a fluid change last year.**
$600.00 OBO, you pick up. located in sacramento. its already sitting on a dolly in my garage.
shoot me an offer, if you catch me on a good day ill probably say yes.
this is a solid motor, burns no oil, and you wont find a better deal for a COMPLETE swap, all the way down to the original ECU.
NO TRADES, unless its ITR engine parts, or the necessary parts needed to do a poor mans type r build.
power steering pump
alternator
starter
timing belt
water pump
head gasket
IM gasket
EM gasket
oil pan gasket
upper radiator hose
ProMotive
Northeast (Sales)
13
07-15-2008 06:34 AM
Scrapin4DR
17
08-02-2005 06:32 PM
