Northern California North of Fresno
91 Honda Civic For Sale!
Old 07-28-2016, 04:25 PM
JDM0873's Avatar
Default 91 Honda Civic For Sale!
I'm helping a friend post his EF up for sale. If you have any questions please contact him via email randall.archuleta@gmail.com
1991 Honda Civic Hatchback
1991 Honda Civic PRICE DROP as of 07/30/16
fuel: gas
title status: clean
transmission: manual
NO TRADES
-BARD B17a1 VTEC swap
-HAVE Receipt and sticker for bar'd swap
-new INTEGRA DA catalytic converter
ENGINE
-B17a1
-92-93 GSR ECU
-TYPE R INTAKE MANIFOLD
-CTR valve train
-CARB LEGAL INTAKE
-HASPORT ENGINE MOUNTS
-new Integra radiator and hoses
-new timing belt and water pump
-new cam seals
-new valve cover gasket
-Yonaka exhaust
TRANSMISSION
-YS1 short gear transmission
-new clutch masters stage 1 ceramic clutch
-resurfaced GSR FLYWHEEL
-ARP FLYWHEEL BOLTS
SUSPENSION
-Ground Control sleeves
-koni orange F, KYB Rears
-350lbs F, 400lbs R springs
-ADJ rear camber arms
-Front CUSCO STRUT BAR (NOT PICTURED)
-Rear EM Racing strut bar
-ES rear trailing arm bushings
-Front HARDRACE upper control arm bushings
-ES REAR control arm
Bushings
-new inner and outer tie rods
-front SI sway bar
-rear ST 22mm rear seat bar with stephetical end links.
DRIVETRAIN
-HASPORT Linkage conversion
-ES SHIFTER BUSHINGS
-B&M short shifter
BRAKES
-Front and rear INTEGRA DA disc brakes
-DA booster and master cylinder
-DA prop valve
-civic EX knuckles with new pressed in wheel bearings
-new brake lines
EXTRA PARTS
-DC HEADER (not on car)
-new slotted and drilled rotors for rear with pads
-HASPORT HYDRAULIC MOUNT
-B16a ECU
-B&M adj. fuel pressure reg.
-VTEC SUB HARNESS
ALL WILL BE FREE UNLESS I SALE
-hero sport shift extender
Have many more part in car. Most of the parts were installed new back in Novemeber along with the swap. Wired for subwoofer and amp as well.
CONS
-typical door dings for an older car
-previous owner put some sealant around windshield
-drivers window sticks when getting to the top.
-Needs front axles, boots are torn
-driver seat ripped
-exhaust rubs sometimes.
Car is not perfect but it drives great and make a great commuter car. I'm asking 3,700 or reasonable offer. Thanks
Old 08-22-2016, 10:13 PM
GDD Member
slomofo's Avatar
Default Re: 91 Honda Civic For Sale!
Interested in trades?
littleredcivic
Northern California (Sales)
01-06-2006 08:13 PM
littleredcivic
01-06-2006 08:13 PM
littleredcivic
01-06-2006 08:12 PM
animalthug19
10-16-2005 09:01 PM
animalthug19
Acura TL, RL & ZDX
04-07-2005 12:42 PM
Quick Reply: 91 Honda Civic For Sale!
