GOTTA GET IT OUTTTTTTT!!!!!!! B SERIES!!! ETCCC
Old 02-15-2012, 10:35 AM
96Dc2 GSR's Avatar
Default GOTTA GET IT OUTTTTTTT!!!!!!! B SERIES!!! ETCCC
89-90 prelude foglights with brackets could be used on 90-91 crxs 25
http://i1000.photobucket.com/albums/...E/IMG_1799.jpg
http://i1000.photobucket.com/albums/...E/IMG_1800.jpg
eg cluster with rpm 121K on it for some reason the temp gauge stays like that but goes right up when the car is started it is fully functional as i tried it in my personal car also the plastic cover is cracked 40
http://i1000.photobucket.com/albums/...E/IMG_1803.jpg
b16 civic si hydro s4c tranny casing, this is both sides of the tranny casing had a junk obx lsd and blew up the threads are fine the inside has a few scratches but talked to a tranny expert and said it was fine it will come bare 100FIRM
http://i1000.photobucket.com/albums/...E/IMG_1805.jpg
http://i1000.photobucket.com/albums/...E/IMG_1808.jpg
http://i1000.photobucket.com/albums/...E/IMG_1809.jpg
http://i1000.photobucket.com/albums/...E/IMG_1810.jpg
http://i1000.photobucket.com/albums/...E/IMG_1811.jpg
http://i1000.photobucket.com/albums/...E/IMG_1812.jpg
98-01 Acura Integra OEM BLACK Type R Lip real lip ll the tabs are in place and has its honda stamp and is 100% authentic 200FIRM
http://i1000.photobucket.com/albums/...E/IMG_1816.jpg
eg cargo cover for hatch holes cut for 6x9s and the end is cracked usable but not 100% 10
http://i1000.photobucket.com/albums/...E/IMG_1818.jpg
eg armrest in black the cushion peice is worn and the back peice where the ashtray goes is cracked 20
http://i1000.photobucket.com/albums/...E/IMG_1820.jpg
00 integra gsr block with main caps and oil squirters still will need a rebuild obviously has alittle surface rust on walls had a spun rod bearing 200FIRM pluss shipping
http://i1000.photobucket.com/albums/...E/IMG_1823.jpg
http://i1000.photobucket.com/albums/...E/IMG_1824.jpg
http://i1000.photobucket.com/albums/...E/IMG_1825.jpg
http://i1000.photobucket.com/albums/...E/IMG_1827.jpg
http://i1000.photobucket.com/albums/...E/IMG_1828.jpg
http://i1000.photobucket.com/albums/...E/IMG_1829.jpg
http://i1000.photobucket.com/albums/...E/IMG_1830.jpg
http://i1000.photobucket.com/albums/...E/IMG_1831.jpg
a whole bunch of rear b series brackets 40 a peice
3 ef/da b series
3 ek/si b series
1 new eg/dc rear bracket
96 acura integra gsr catiylic converter with 2 o2 bungs it will not have the o2 attached 70
eg civic power side mirrors has its scuffs from moving around 20
http://i1000.photobucket.com/albums/...E/IMG_1835.jpg
http://i1000.photobucket.com/albums/...E/IMG_1837.jpg
96-01 acura integra 4 door side mirrors blue also have its stuffs from laying around 20
http://i1000.photobucket.com/albums/...E/IMG_1839.jpg
http://i1000.photobucket.com/albums/...E/IMG_1840.jpg
ek door tweeters SOLD
crx amber corners 5
eg/dc 3 post mount b series 30
integra dual bend shifter 10, b16 speed sensor 30, b16 cable speed sensor 20, 5 small iacv ALL SOLD, 2 stock b series FPR 5 a peice, 4 crank pulleys not sure what is what 25
http://i1000.photobucket.com/albums/...E/IMG_1848.jpg
http://i1000.photobucket.com/albums/...E/IMG_1849.jpg
http://i1000.photobucket.com/albums/...E/IMG_1852.jpg
http://i1000.photobucket.com/albums/...E/IMG_1853.jpg
http://i1000.photobucket.com/albums/...E/IMG_1854.jpg
crx aftermarket bumper lights 5
b series spark plug cover 10, obd2a-obd1 jumper harness 40, b16 breather box 5, gsr breather box 5, b16 thermal intake manifold gasket 15
http://i1000.photobucket.com/albums/...E/IMG_1856.jpg
http://i1000.photobucket.com/albums/...E/IMG_1857.jpg
http://i1000.photobucket.com/albums/...E/IMG_1858.jpg
http://i1000.photobucket.com/albums/...E/IMG_1859.jpg
http://i1000.photobucket.com/albums/...E/IMG_1860.jpg
http://i1000.photobucket.com/albums/...E/IMG_1861.jpg
http://i1000.photobucket.com/albums/...E/IMG_1862.jpg
timing covers b series 10 dollars a peice
3 obd2 timing belt lower timing belt covers
3 gsr middle covers one cut up top to install cam gears inside car
1 pr3(b16) middle cover
as for the outters just hit me up it says pr3, pr4 and p72 so ill know what is what
http://i1000.photobucket.com/albums/...E/IMG_1863.jpg
da cargo cover has crack or rip on the end 10
skunk2 cam gears one has a crack where the key is the other has new timing marks on it due to it rubbing off, but it was used and worked perfectly fine no slips and no stripped bolts 60
http://i1000.photobucket.com/albums/...E/IMG_1883.jpg
http://i1000.photobucket.com/albums/...E/IMG_1884.jpg
http://i1000.photobucket.com/albums/...E/IMG_1887.jpg
00 b16 throttle body no tps and no thing to hook up the trottle cable 20
basically i took the time to post up pics so no message tag most of the prices are firm but ill combine shipping if anything certain big things i will not shipp out like the cargo covers and type r lip as of right now..well it depends i accept paypal only for more info or faster responds text me at 7816062829 the pics are there just look please and prices are right at the end
96Dc2 GSR is offline
Old 02-16-2012, 06:22 AM
96Dc2 GSR's Avatar
Default Re: GOTTA GET IT OUTTTTTTT!!!!!!! B SERIES!!! ETCCC
bumpppppppppppp
Old 02-17-2012, 06:27 AM
96Dc2 GSR's Avatar
Tttttt
Old 02-17-2012, 10:15 PM
96Dc2 GSR's Avatar
ttttttttttt
Old 02-18-2012, 03:28 PM
Bartman201's Avatar
pm'd you
Bartman201 is offline
Old 02-19-2012, 11:22 PM
96Dc2 GSR's Avatar
sorry im not willing to shipp the cargo tray as of right now
Old 02-22-2012, 05:54 AM
92egvx's Avatar
where u located interested in the tranny casing
92egvx is offline
Old 02-23-2012, 03:09 PM
96Dc2 GSR's Avatar
boston mass, the bell housing is already sold though
Old 02-23-2012, 03:15 PM
minibiker199's Avatar
Bumppppp
minibiker199 is offline
Old 02-24-2012, 06:10 AM
96Dc2 GSR's Avatar
ttttttttttt
Old 02-26-2012, 01:05 AM
96Dc2 GSR's Avatar
tttttttttt
Old 02-29-2012, 04:33 AM
89blackef's Avatar
Do you happen to have that b18c1 block still?
89blackef is offline
96Dc2 GSR
03-07-2012 04:14 AM
1990hondaHF
02-03-2009 08:41 AM
rdt
01-02-2007 05:44 AM
Quick Reply: GOTTA GET IT OUTTTTTTT!!!!!!! B SERIES!!! ETCCC
