▐▐▐▐▐ PRIVATE LABEL MFG H2B SWAP KIT AND H2B HEADER ▐▐▐▐▐
PM FOR FORUM PRICING!
The Private Label MFG H2B Swap Kit is perfect for drag racing and is designed specifically for converting your H or F series Honda block to run a B-series transmission. The B-series 5spd transmission gives you more flexibility since it comes in many different gearing options as opposed to just being standard on the H/F series models.
This H2B kit allows you the enthusiast to mount any B series manual transmission to any H or F series motor in a 92-95 Honda Civic (EG chassis), 96-2000 Civic (Ek/EM chassis), or 94-01 Acura Integra (DC chassis)
Features
• Brand New In Box
• H2B Adapter Plate
• Crankshaft Spacer
• Engine Mount Bracket
• Clutch Slave Spacer
• Intermediate Axle Adapter
• Bolts
• Fasteners
Private Label MFG Power Driven H2B SWAP HEADER features a true step up exhaust header design. The two-piece design header delivers low to mid range power while maximizing engine compartment space for this exhaust manifold. The header is ideal for all forms of competition; auto-cross, drag racing and road racing.
Recommended for H2B swap cars with H-Series motors with B-series transmissions.
Features
• Brand New In Box
• Made of 304 Stainless steel
• One year limited warranty
• Short tube Tri-Y header
• True 2.5" collector
• Machined CNC-ed manifold flange
• Flange is .38" which is just about 3/8" thick
• 18G on the 304 S/S. Measured at .049" to .050"
• two piece design
__________________________________________________ _________________
PAYMENT OPTIONS:
Paypal ID & INFO: HONDAPARTSALES@gmail.com
If purchasing with Paypal please remember to confirm your address with paypal prior to placing the order. The reason we require confirmed addresses is so that both parties are protected via Paypal Buyer/Seller Protection Policy. If you're unsure on how to confirm your address with paypal you can contact them directly and they will walk you through it.
PAYPAL ORDERING:
When using Paypal to purchase, please make sure that you leave your order info in the notes section of Paypal. (Ex: Hytech Standard Tube H-T Special $325 w/ free shipping) This helps us process your order quickly and correctly. Please note that this is very important as if there are no notes left on the payment it will delay your order.
DEALER/WHOLESALE INQUIRES ARE WELCOME
