f/s-f/t tucked and built 1997 civic
I have had this car for almost two years now and love the thing but want to see whats out there. The car was built by me and the motor machine work was done by Bailey Motorsports. The car has been running for 2-3k miles now with no problems and pulls very hard.
*innovative mounts with stiff bushings(no marshmellow bushings)
*The car has a si front end(not because of a crash) i bought the front end from chicago and the paint matches perfectly.
*Full interior besides the trunk matting
*Buddyclub bucket seat with low mount brackets
*Pioneer Deck
*Koni Yellow/Ground Control (bought new, great condition)
*Rota flashbacks Falken 912 tires(Both brand new, just shipped to my door earlier this week)
*Extended top hats
*Tucked fuse box(NO AIRBAGS, fusebox is in the airbag location)
*Battery relocation
*Custom clutch line that runes behind the firewall, through the frame and to the slave cyl.
*Tucked brake lines(all mounted and riveted) kept heat
-Integra master
-Integra booster
-Integra prop valve
all you need are the spindles and you have a civic with tucked brake lines and integra brakes
MOTOR
*B18c1 (81.5 mm) with gsr trans
*ls crank
*Eagle rods with upgraded bolts
*mahle 10.5.1 pistons
*all new waterpump,timingbelt,oilpump,gaskets, etc.
*supertech springs
*supertech retainers
*supertech keepers
*supertech flat face high compression valves
*crower stage two n/a cams
*new oem headgasket
*ARP headstuds
*STR adjustable cam gears/cam cap
*Blox intake manifold(port matched to throttle body)
*Omni 70mm Throttle boddy
*kiddracing replica header(2 1/2 inch collector)
i know im forgetting some stuff but thats a good amount of it.
BAD: Rear bumper is not in good condition, driver window bracket(on the window) is broken) i will be getting a new window and looking for a new bumper
_INTAKE IS GAY..I KNOW workin on gettin a new one
(clutch line, thats all you see, the rest is through the frame and behind firewall)
(prop valve located right behind cup holders under the dash)
Mr.Johnson drivin my car, me in the dope hatch
Flyin by a type r hatch goin 135
*Pioneer Deck
*Extended top hats
*Battery relocation
-Integra master
-Integra booster
-Integra prop valve
MOTOR
*ls crank
*supertech springs
*supertech keepers
*new oem headgasket
*ARP headstuds
Re: f/s-f/t tucked and built 1997 civic
lol i love it, got it all the way down and took the cushions on the bottom out so im basically sitting on the floor
I would suggest dont get all creative with your pictures
try to rest the camera on something like a tripod
side shot bay shot and int shot
NO LEGS
Willing to work out a deal? Let me know.
http://hondamarketplace.com/showthread.php?t=2634478
ok for the people who want "normal" pictures.. Sorry i didnt take pictures to sell the car i took them to mess around, like is said before my camera is about 10 years old and takes pictures that look like motion blurry shots, if you are actually interested then pm me and i will hook you up with pictures or even meet up so you can see it. I APPOLOGIZE
Thank you for the offers sent through pm's i have pm'd back
_Tough4life like your crx but i am looking for a newer car
