**OFFICIAL** OEM EG / DC Sidemarker Template
Here it is folks, a PDF that you can print out at actual size to use when cutting holes for EG or DC sidemarkers. The measurements for the hole itself is the same for both cars, but the diagram shows the distance above the fender molding for EG fenders. I can try to make another diagram later that shows the placement on DC fenders.
The dashed oval indicates the actual outline of the sidemarker housing, while the darker line indicates the hole you need to cut. Yes the notches are required so that the sidemarker will fit into place.
All measurements are in millimeters.
When printing the PDF file to 8.5x11, make sure the PDF print options are set to "None" for Page Scaling. If set to something like "Fit to printable area" then it will NOT print out at the correct scale. Whatever you do, I highly advise that you verify the measurements with a metric ruler just to make sure. On our printer at work, it prints out perfectly. If you set yours to no page scaling and it doesn't come out right, then there's something wrong with your printer.
Re: **OFFICIAL** OEM EG / DC Sidemarker Template
So is the the left oval for the driver side and the right oval for the pass. side, or vice versa?
I take it the large oval on the bottom is the fender molding?
Anyone know where I can be sidemarkers + wiring online? I know PWJDM has them but I was wondering if there was anywhere else. Thanks!
Anyone know where I could find a templete for DC sidemarkers on DA? Im not sure how thats gonna work..that diagram looks very confusing..
has anyone ever put da sidemarkers on a dc? cuz i wanna get sum sidemarkers for my dc but im not sure i like the flat looking sidermarkers. i like the da ones but i dnt want my car to look like a ricer with the wrong sidemarkers
anyone know exactly where i should wire these side markers since i wired them to my corner lights but everytime i shut my door the amps spike to like 30 some and blow the fuse everytime. i have no idea was the problem is
sorry to re-open this thread up but the question wasn't really answered. so the oval on the left is for the drivers fender, and the one on the right with all the measurements around it is for the passenger fender? I got that the big oval on the bottom is the moldings, just making sure on the other part.
Thanks for posting this up man
