k24a2 with element /crv ecu
Old 06-03-2023, 09:08 AM
notsonerdy's Avatar
Default k24a2 with element /crv ecu
does anyone have experience on running this set up
will it run fine w/o codes... It would get a k pro in the future
Old 06-03-2023, 07:49 PM
JRCivic1's Avatar
Default Re: k24a2 with element /crv ecu
It will NOT run fine... totally different injector size and VTEC cross-over point just to name a couple of obvious issues. You will need a tuning solution to make it run correctly... meaning you need KPro immediately after installing the engine.
Old 06-03-2023, 07:53 PM
notsonerdy's Avatar
I talked to a couple of people who have done the swap at different importers - they said it will idle fine and smog, but there are some hiccups around 3500 and 5500.
im not trying to race it, just trying to daily... one suggested that another ecu can be flashed to the TSx fuel maps
-Justin-
Honda CR-V & Element
09-18-2018 01:15 PM
ef_you_again
17
03-28-2005 07:49 PM
Quick Reply: k24a2 with element /crv ecu
