k series swap in a 1992 Civic Dx / k20a k20 k24a swap info
#51
Re: (Karcepts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karcepts »</TD></TR><TR><TD CLASS="quote">
The mounting kit is only designed for use with the RSX shifter boxes and cables. If you wanted to use an H-series shifter assembly, your best bet would be to mount the shifter on top of the tunnel without the kit. You would then have to drill a hole in your firewall for the cable routing and you may have to hack up your cup holder area within the console. When using a K-series motor (non-TSX tranny), I would highly recommend just using the RSX shifter box and cables for simpler install, cleaner appearance, and proper function.</TD></TR></TABLE>
I'd like to bump for Brian @ KARCEPTS. This guys workmanship is the best I've seen. Whenever and where ever he goes and pops his hood and with the cleanest K swap around everyone is drop jawed.
Great products and great workmanship plus this guy won't disappear like some other K series guys. He is committed to the Honda community.
He can also autocross fairly well for a spastic driver.
#52
HT White Ops
Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">I forgot to add.
With hasport mounts, you can make your own axles by combining rsx and gsr axles. ( bseries)
It is pretty straight forward how to do it.
Here's the article
http://www.theksource.com/news...brids/</TD></TR></TABLE>
Did anybody ever find out if this trick, or one that is similar, will work with the Hybrid mounts?
Here's the article
#53
Re: (Nikos)
Great write up NIKOS. Also thanks to KARCEPTS for the customs mounting for the shifter and radiator. Great products. I know i will be getting some of these parts from u soon for my soon to be K20a EK.
P.S. THE BEST K SERIES WEBSTIE...... K20a.org
#56
#58
Re: (Vtec_Tommy)
here are some pics
the engine bay with the brackets and mounts attached
the mounts will be attached to the motor, I just have them here so you can see how the motor will be attached
and here's the motor going in as soon as honda dealer gets me a few bolts I need
#61
Re: k series swap in a 1992 Civic Dx / k20a k20 k24a swap info (Nikos)
sick! maybe someday when i find some money chillin somewhere, i'll throw a K series into my EF 4 door! that would be pimp to spank on somebody with 4 heads in the car!!! LOL
#62
Re: k series swap in a 1992 Civic Dx / k20a k20 k24a swap info (89EFeight)
Nice writeup
I have a question about what parts that can be used from a EDM STREAM with a K20A1 engine (150 hp). This is the only crashed K-series car I have found here in Denmark. I'm thinking about engine harness, axles, tranny, sensors etc. I'm building a K24/K20A drag EG so I just need stuff for racing
#63
Re: k series swap in a 1992 Civic Dx / k20a k20 k24a swap info (CRXEE8)
I sell axles for the k20 into eg and integra swap and a kit for the fuel lines as well...qauife, rods, pistons...you name it...
Tommy @ http://www.fast-turbo.com
Toll Free: (888) Turbo 58 (887-2658)
Int'l (817) 439-3748
#65
Re:
(Nikos)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I forgot to add.
Here's the article
what if you are using a 36 mm hub such as JDM ITR 5 lug? then could you use the RSX axles unmodified ?
Here's the article
#66
Juts wondered, does those aftermarket headers same / swapable from all cars with stock K series block? I mean i have a new CRV and want to get a better header..
#70
Re: (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">hey nikos something i wanted to know. i know a member on here "civic dx" put a k into his EG coupe and he went into detail about having to shave down the steering rack to clear the tranny ? whats that about ? and has anyone had this problem ?</TD></TR></TABLE>
-Chameleon I have that problem with mine, causes a bit of vibration at higher rpms. I was told by hasport that of 5 cars they did 3 of them cleared the ps rack no problem. The other two didnt, and appeard to have been in a wreck or curbed one time in there life bending it. Also there is room for adjustment on the rack by loosening the bolts and sliding it back a smidge. I still have yet to try this.
Also for the power steering line, since i had a wrecked rsx-s, I simply took the stock p/s line from the rsx-s and it screwd directly into my rack. I had to bend it a smidge but the length was perfect and overall it worked fine. This was on a Si 95 hatchback btw...
As for the wiring, ive never wired up anything aside of a pioneer cd player in my car. I paid someone to have my alarm installed because I couldnt figure it out, yet I managed with the help of the forum to wire up my kswap completely running. So its not that bad.
Oh and thanks Nikos again youve saved me numerous times
#72
Re: Re: (SleepRdc2)
I did a read up on the axle thing on k20a.org...it seems like the passenger side is going to be short. Something about flipping the inner hubs to compensate for it. Not 100% sure but there is a good thread about it there. Some people have different opinions about it though...hence the confusion on my part
