Will a f20b cam work in a h22 head
I got a f20b in my civic that I'm swapping with a built h22 as far as the head I was gonna port and I have super tech springs and retainers can I use the f20b cams because I heard they're the same as the type s? I do know my f20b has a h22 intake manifold on it so I assume everything interchange except the valves. It will be going on a turbo application 500hpish
Re: Will a f20b cam work in a h22 head
Yes, the F20B cams can be used in the H series head assuming you are using a set of valvesprings that work with the cams.
