vtec!
Old 10-04-2012, 09:53 AM
barametric's Avatar
Icon7 vtec!
the car is usdm civic si. the ecu is stock. the engine is b16a, what should i use to control the vtec with. also what happens in the ecu when vtech engages: timing changes? fuel changes? both? any help would be great.
Old 10-04-2012, 11:52 AM
Eclectia's Avatar
Default Re: vtec!
Need more info. USDM civic si covers vehicles from the 80s to the present. I also need to know which ecu you are using.
Old 10-04-2012, 11:57 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Default Re: vtec!
Are you trying to get Vtec co "crack" earlier?
Old 10-04-2012, 01:13 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: vtec!
Don't change the VTEC setting.
Old 10-05-2012, 08:01 AM
barametric's Avatar
Default Re: vtec!
its a pm6 and 1991 year.
Old 10-05-2012, 08:03 AM
barametric's Avatar
Default Re: vtec!
i just want it to work.
Old 10-05-2012, 08:06 AM
Technical Hero
Default Re: vtec!
Get the correct ECU OBD0 PR3 or PWO
Old 10-05-2012, 08:12 AM
JuggerNaut-CTR's Avatar
Default Re: vtec!
Non vtec ecu for a vtec engine...hmmmmm. Wonder why its not working?
Old 10-05-2012, 09:55 AM
barametric's Avatar
Icon7 Re: vtec!
thanks thats a good idea but what if i used one of those apexi neo controllers,could i set it up so it only corrected and changed things when the vtec turned on? or do these only work on vtec ecus.
Old 10-05-2012, 09:59 AM
been there done that
doood's Avatar
Default Re: vtec!
stop half assing **** and do it the right way
Old 10-05-2012, 10:00 AM
barametric's Avatar
Default Re: vtec!
yea but its got a great mix of power and economy. and thanks for the flaming i love it when people do that.
Old 10-05-2012, 10:05 AM
barametric's Avatar
Default Re: vtec!
but i like twiddling ***** and buttons.
Old 10-05-2012, 10:10 AM
cvcrcr99's Avatar
Default Re: vtec!
Then buy one and see if it works if you like to go in circles and buy things twice. The ECU isn't set for it. Only way I have seen a non vtec ecu run vtec is if the OBD1 ecu is chipped.
Old 10-05-2012, 01:46 PM
barametric's Avatar
Default Re: vtec!
are all pr3 ecus obd0, i have researched them and thought they used two o2 sensors. was i wrong? is there a pr3 that is obd1.
Old 10-05-2012, 02:21 PM
Technical Hero
Default Re: vtec!
There is an OBD1 PR3 ECU. The obd0 pr3 and pwo use two single wire 02s where as the obd1 uses a single 4 wire 02.
alx_90ef
11
04-27-2009 08:07 PM
integra3586
10-15-2007 03:22 AM
moosepoop21
08-29-2006 05:39 AM
DOHC-V-TEC-DA
02-03-2006 06:03 PM
Quick Reply: vtec!
