please help, b16a into 94 eg couple motor mounts..NOT INTEGRA
Old 07-17-2005, 08:06 PM
the.hamburglar's Avatar
Default please help, b16a into 94 eg couple motor mounts..NOT INTEGRA
hey i have a problem. i searched and found that everyone is using 94-2001 integra motor mounts for this swap. so i have this car with the swap already in and i just bought new jim fab motor mounts for a 94 integra and there is no way they are going to fit. could you please check out this pic and let me know what you think i have for motor mounts already in there? becuase i need to get new ones soon before the turbo
Old 07-17-2005, 08:08 PM
Default Re: please help, b16a into 94 eg couple motor mounts..NOT INTEGRA (hamburgler)
this is a jdm b16a i dont know if that will make a difference. i dont know what year though
Old 07-18-2005, 01:10 AM
the politician's Avatar
i thought that jim fab mounts are the two front torque mounts an the rear mount. so the mounts your looking at are the wrong ones. but im not exactly sure.
Old 07-18-2005, 10:14 AM
Default Re: please help, b16a into 94 eg couple motor mounts..NOT INTEGRA (the politician)
oh, where are the torque mounts???????
Old 07-18-2005, 07:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote">oh, where are the torque mounts???????</TD></TR></TABLE>
the torque mounts are ones at the end of the ac bracket and bolts to the underside of the driver side frame rail, and at the end of the front tranny bracket that bolts to the underside of the passenger side frame rail.
Old 07-18-2005, 08:48 PM
so i have to take out the ones i took a pic of to get at them?
Old 07-19-2005, 12:19 PM
klungemonger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote">so i have to take out the ones i took a pic of to get at them?</TD></TR></TABLE>
No! The ones in your pics are totally unrelated to the torque mounts. I wrote in your other thread also...torque mounts you get at from underneath the car, easy stuff. Do them one at a time, pull the large nut off on the outside of the mount...you might have to remove the lower splash shields to get at them. Then remove the 2 bolts holding the mounts to the frame and slide the mount off. Slide the JimFab mount on and bolt it all back together.
Old 07-19-2005, 03:03 PM
Default Re: please help, b16a into 94 eg couple motor mounts..NOT INTEGRA (klungemonger)
yeah i see that now, makes sense to me hence the name torque mounts! ill put them on tonight
Old 07-19-2005, 08:21 PM
They are called torque mounts because they are oriented in the direction of the crankshaft, they control the engine from rolling when you load it.
Old 07-26-2005, 03:40 PM
EK9Greg's Avatar
ok ok ok this is what is going on the tranny mount is a stock d16 mount it is kinda the same as a LS mount but alittle different but it works just *** good, the drive side mount is the same stock eg d16 mount the integra has a 3 bolt mount on that side, it you want to get new one make sure you get the driver and passenger eg stock mounts replacments and the rear mount if you are getting that get a GSR integra or an LS integra mount you should have know problems
jayeghatch
18
09-19-2012 07:56 AM
the.hamburglar
06-21-2005 10:16 AM
the.hamburglar
06-10-2005 10:26 PM
92Integra
02-13-2004 09:19 PM
Quick Reply: please help, b16a into 94 eg couple motor mounts..NOT INTEGRA
