Not getting any spark in my b16
I just put a first gen B16 in my 91 STD when I go to start the car it turns over but I am not getting any spark, I replaced the cap and rotor and the ignitor, and still am not gettting any spark. I am going to replce the coil tommorow, until then does anyone have any other ideas what might be causing this problem? Thanks
Re: Not getting any spark in my b16 (b16EF)
check for codes man?!?!
t..
on EFs you check the code AT the ECU so your dash would have nothing to do with it. are you absolutely sure its no spark? did you verify this using a screwdriver in a spark plug wire or what?
Re: Not getting any spark in my b16 (sleeper4dr)
Re: Not getting any spark in my b16 (tinkerbell)
when I did my swap I couldnt get it to start either for like almost a full day we tried everything.we checked the distributor,plug wires ,and changed the spark plugs.......anyways all it ended up being was clogged fuel injectors.We cleaned those and walla it fired right up.maybe something to try.
aaronhume
25
03-22-2005 08:42 PM
RussHondaCRXVtec
12-17-2003 10:40 PM
