h22 swap wiring question???
Old 01-10-2008, 08:56 PM
eg_h22's Avatar
Location: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
Default h22 swap wiring question???
I have a 95 dx and swaping a h22. I am using a p28. How do I go about wiring vtec. I'm running the wire through the shock tower harness and to the ecu plug but there isn't a female pin where I need to add the wire. The female pin is smaller than the ones I can salvage off my scrap harness. What pinout do I run the wire to and HOW?
sorry if it sounds confusing. I tried to be clear. Thanks
Old 01-10-2008, 09:09 PM
I'm really 2slow
2fast4u831's Avatar
Default Re: h22 swap wiring question??? (eg_h22)
A4 is vtec solenoid, D6 is oil pressure switch, the black is a ground
you will need some of those small female connectors from another ecu harness plug. wrecking yard has many good luck
Old 01-10-2008, 09:17 PM
eg_h22's Avatar
Default Re: h22 swap wiring question??? (2fast4u831)
Thanks man. I needed to confirm that I am doing what I am supposed to.
Old 01-11-2008, 06:37 AM
I'm really 2slow
2fast4u831's Avatar
make sure you get different size female connectors. there are 2 different sizes and you will need both
Old 01-12-2008, 05:24 AM
gibsanez's Avatar
You aren't using a stock P28 are you?
Old 01-14-2008, 10:21 AM
eg_h22's Avatar
Default Re: h22 swap wiring question??? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">You aren't using a stock P28 are you?</TD></TR></TABLE>
no. its a chipped phearable p28. give me a little credit man its just my first time doing anything like this
Old 01-14-2008, 10:25 AM
eg_h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get different size female connectors. there are 2 different sizes and you will need both </TD></TR></TABLE>
yeah. I salvaged the bigger ones from my scrap harness. just don't have the smaller ones for the ecu plug
Old 01-18-2008, 02:42 PM
eg_h22's Avatar
Man! none of the salvage yards around me will let me just take a couple small female pins. Or won't let me just cut the ecu plug. They all sell the harness as a whole for like $75!(forget that)
What else can I do!?
usdmftw
07-04-2011 11:25 AM
h22lude317
06-02-2009 03:01 PM
omarisramo
08-05-2008 01:45 PM
omega_s14
10-31-2005 04:45 PM
Quick Reply: h22 swap wiring question???
