f22a6 crank in h22a1 block help help help
I have a h22a1 with a f22a6 crank. i no it's not the big daddy crank but what rods should i use?? I have done more reading on this i no the f23 crank is larger but i want to try something new. can I run the f22a6 crank with the stock H rods an pistons in my h block.
Re: f22a6 crank in h22a1 block help help help
H & F Series Engine Info
^This one in particular.
since the rod length is different but the rod journals are the same you'll simply be doing a "stroker" H22A1. just swap the crank and leave everything else as is.
trucdoken
08-24-2005 08:01 PM
