EGR valve on H22 EK Civic.....
Old 04-10-2004, 09:58 AM
Honda_Tengoku's Avatar
Default EGR valve on H22 EK Civic.....
Ok I currently have an H22 in my Civic. I am still finishing up the swap. Currently I do have the EGR valve wired in. I am also using the P13 ECU. I do not want a check engine light over the EGR valve (code 12). Where do I hook the vacumm lead up to? How do I get the EGR system to work correctly? What extra items to I need? I have looked at the vacumm diagrams.(EGR control solenoid valve, EGR vacumm Control Valve). Is that all I need ? Or do I even need them? Thanks for any advice.
Old 04-10-2004, 10:31 AM
Turbogixxer's Avatar
Default Re: EGR valve on H22 EK Civic..... (Honda_Tengoku)
EGR Wiring Info
USDM wire colors are the same as JDM.
Connector colors means that when looking at the connector (wire pointing towards you) that the way they should line up (From left to right)
EGR lift valve solenoid
(The connector colors, From left to right) BLK/YEL and RED
Sensor Voltage - BLK/YEL - goes to A25
ECU trigger - RED - goes to A11.
EGR Lift Sensor (the actual EGR on the intake manifold)
(The connector colors, From left to right) WHT/BLK, GRN/WHT, and RED/WHT
ECU trigger - WHT/BLK - goes to D12
Sensor ground - GRN/WHT - goes to D22
Sensor voltage - RED/WHT - goes to D19 or A25
Old 04-10-2004, 07:34 PM
BOOSTonHAnD's Avatar
is the egr valve needed? im not sure in what it does. thanks for any info.
Old 04-11-2004, 12:39 PM
MPower332TI's Avatar
Default Re: (hartlessEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hartlessEK &raquo;</TD></TR><TR><TD CLASS="quote">is the egr valve needed? im not sure in what it does. thanks for any info.</TD></TR></TABLE>
Its not needed for performance at all but it will throw a code every once and awhile. It recirclates the exhuast gases back through the intake, kinda like a smog pump.
akouznet
10-16-2009 08:03 AM
hpi247
05-30-2007 06:16 PM
hpi247
05-20-2007 09:32 AM
kevlh18
10-29-2006 03:57 PM
HT Chaplain
06-26-2004 07:11 PM
Quick Reply: EGR valve on H22 EK Civic.....
