civic swap map/idle probs still
Old 07-22-2005, 12:07 PM
5thGenFanatic's Avatar
Default civic swap map/idle probs still
hi..i am posting this in a couple forums other than where it should be because noone else seems to be able to help me...i would like to see if someone from the delaware area (northern) would be willing to stop by sometime and help me figure out what is wrong with my car...ive already tried the suggestions thing on here to no avail.. i need a really good person willing to stop over..if you can help me figure out what the problem is ill give u like a hundred bucks...im having map issues with a swap i did from my integra to my civic...jdm motor, gsr trans, complete harness, no splices or cuts at all...ecm..basically a direct swap..ran fine for a year in the teg..ive tried everything..its throwing a code 3 and idle wont drop from 1400 even when warm...i tried vacuum checks and leak checks, 3 map sensors, spare ecm, cleaning all the connectors, iac and tps just for the hell of it...not fixing..need help.going nuts..wanna get back to track....PLEASE SOMEONE GOOD!!!!!..... my email is LoradoLr@aol.com..
Old 07-22-2005, 05:30 PM
GDD Member
slomofo's Avatar
Just a shot in the dark, have you tried swapping throttle bodies?
Old 07-22-2005, 08:03 PM
eda6's Avatar
Default Re: (slomofo)
have you ohmed out the map sensor circuit? Made sure all the wires are landed in the correct pins at the ecu?
Old 07-22-2005, 08:09 PM
GDD Member
slomofo's Avatar
Nobody here knows your problem, but i'm sure that when you do find the problem it's going to be something sooooooooo stupid you just want to kick yourself, something like a throttle body gasket or low coolant level...either way, good luck to you.
Old 07-26-2005, 01:02 PM
bump
5thGenFanatic
07-28-2005 10:16 AM
5thGenFanatic
07-26-2005 03:56 PM
5thGenFanatic
07-26-2005 01:05 PM
5thGenFanatic
07-26-2005 01:03 PM
5thGenFanatic
07-26-2005 01:00 PM
Quick Reply: civic swap map/idle probs still
