93 civic/H2b swap - injectors not firing
Old 11-30-2015, 05:27 AM
BIGef's Avatar
Default 93 civic/H2b swap - injectors not firing
I have a 93 civic hatch with an h2b
It has fuel pressure
Has spark
Main relay clicks when on "on position"
When on "on position" cel stays on doesn't turn off the fuel pump primes
Checked codes it's the "iat" code 10 but I know that won't cause it to start
Has fuel cell and external fuel pump on the engine bay
Fuel pump is wired to body ground and power wire is wired to the wire that leads to the stock fuel pump wire yellow/green wire.
So it primes like stock when on position
But doesn't start it has 10.9 volts on the injector plugs
I'm clueless on what to do any help please
Tia
Old 11-30-2015, 06:15 AM
Former User's Avatar
Default Re: 93 civic/H2b swap - injectors not firing
1) Verify that the injector ground wires properly pin to the ECU
2) Test for continuity to body ground at all ECU connector ground wires
Old 11-30-2015, 04:01 PM
BIGef's Avatar
What pins should I test?
Old 12-01-2015, 09:51 PM
Steve at Heart
Bently_Coop's Avatar
Which injectors? Which Engine? Which Harness?
Old 12-13-2015, 11:51 AM
pleej's Avatar
I had this prob with mine. Turned out 3 of the injectors were fride . Pull them out earth one of the connectors and just tap the other connector with 12v . They shoulf click. If they all click then put them back in the rail and zip tie them to the rail. Then put them in 4 bottles and crank the car. You should see fuel spraying into the bottles.
street_ride14
12-11-2020 07:43 PM
salemned
09-07-2017 12:13 PM
Scout1856
Honda Civic (2001 - 2005)
08-06-2016 01:01 PM
rebel1988us
37
11-26-2012 08:54 AM
on-site ej1
04-03-2009 09:30 AM
Quick Reply: 93 civic/H2b swap - injectors not firing
