[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
#2001
Re: Ecu Pinouts (everlasting1832)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 »</TD></TR><TR><TD CLASS="quote">So ive done some searching and here is the pinouts for the h22 wiring. So now im actually going to try and see if I can wire up this h22/integra wiring myself. any first timer tips would be great!!!!!</TD></TR></TABLE>
Thats great, start diving into it and ask questions. It is the best way.
#2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 »</TD></TR><TR><TD CLASS="quote">seems like most of the colors match right up. it looks as easy as installing a cd-player.</TD></TR></TABLE>
It is not crazy hard, if you have a question ask, it is better then not asking and blowing somethign up
#2004
This is my plan for the h22 wiring. Buy an 00-01 obd2b gsr engine harness. Cut off at about 1.5 feet off the engine harness. Now since hmotorsonline sold me an h22 with the engine harness cut after the shock towers, i will not be needing to cut my h22 harness, just use the shock tower plugs. Every wire im going to read what that wire does for each harness. for example Integra harness is
Fuel Injector #1 =Brown
will run to Fuel Injector #1=Brown from the h22 harness. sounds too easy to be true. looks like alot of the engine harnesses color codes match right up. only wiring that doesnt match up are anything after the engine harness and ecu pinouts. so what confuses me is that the ecu pinouts dont match up. for example,
A3 for the obd1 ecu =INJ2 INJ2 Red, Battery Voltage with KOEO
but the A3 for the obd2b ecu =Evap Bypass Solenoid valve
Blue.
A. Would a OBD2b to OBD1 conversion fix this problem.
B. I would have to route the wire to the correct pinout.
Modified by everlasting1832 at 3:13 PM 1/20/2006
Blue.
#2005
I just recently put all the prelude smog equipment into my civic, wired it all up, ran vac lines etc. Im not throwing a code but the car is running in open loop ( idles at 1200, wont hit vtec, runs crappy) And when i first started it up, it would not run with the EGR plugged in, electricaly, but i could plug it in after starting it and it would run, but if i turned the car off and tried to restart it it wouldnt. do you think the EGR is physically bad? i have the oem honda manual and i did all the vaccum tests on it and it checks out. Or do you think i have a vaccum leak somewhere else?
#2006
Re: Ecu Pinouts (H22poweredNoob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22poweredNoob »</TD></TR><TR><TD CLASS="quote">I just recently put all the prelude smog equipment into my civic, wired it all up, ran vac lines etc. Im not throwing a code but the car is running in open loop ( idles at 1200, wont hit vtec, runs crappy) And when i first started it up, it would not run with the EGR plugged in, electricaly, but i could plug it in after starting it and it would run, but if i turned the car off and tried to restart it it wouldnt. do you think the EGR is physically bad? i have the oem honda manual and i did all the vaccum tests on it and it checks out. Or do you think i have a vaccum leak somewhere else?</TD></TR></TABLE>
if you ran a p28 ecu, it wouldnt check for the egr.
#2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22poweredNoob »</TD></TR><TR><TD CLASS="quote">no im using a p13 ecu and i want it to use the egr because i live in cali and want to pass smog</TD></TR></TABLE>
I just noticed you live five minutes away from me but I have never ran my EGR.
Turbogixxer can help you
#2009
my friend had the same problem you were having on his impreza.. but since we live here in the midwest and we dont smog our cars, he had his egr valve blocked off with just a sheet of metal. but his car just kept idling all weird and ran like ****. we looked for the problem all day couldnt find it. turned out his intercooler wasnt even connected. i suggest looking for any leaks.
#2010
EGR Wiring Info
USDM wire colors are the same as JDM.
Connector colors means that when looking at the connector (wire pointing towards you) that the way they should line up (From left to right)
OBD1
EGR lift valve solenoid
(The connector colors, From left to right) BLK/YEL and RED
Sensor Voltage - BLK/YEL - goes to A25
ECU trigger - RED - goes to A11.
EGR Lift Sensor (the actual EGR on the intake manifold)
(The connector colors, From left to right) WHT/BLK, GRN/WHT, and RED/WHT
ECU trigger - WHT/BLK - goes to D12
Sensor ground - GRN/WHT - goes to D22
Sensor voltage - RED/WHT - goes to D19 or D20
OBD2
(The connector colors, From left to right) BLK/YEL (ORG harness side) and RED (BLK/YEL harness side)
ECU trigger - BLK/YEL - goes to A7
Sensor Voltage - RED - goes to Key switched power.
(The connector colors, From left to right) WHT/BLK, GRN/BLK, and YEL/BLU
ECU trigger - WHT/BLK - goes to D9
Sensor ground - GRN/BLK - goes to D11
Sensor voltage - YEL/BLU - goes to D10
EGR Wiring Info
OBD1
OBD2
#2011
^^^^^lol. i know that page WELL.
??????? for the EGR Lift Sensor. are there other wires i can splice into in the engine harness for the below:
i have the Sensor ground (- GRN/WHT - goes to D22) taken care of already.
or will i have to just run these wires from the sensor to the ECU? pimp plug will added in this case.
#2012
Re: (kurtywompus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurtywompus »</TD></TR><TR><TD CLASS="quote">^^^^^lol. i know that page WELL.
You only have to run two wires to the ECU, D12 and A11.
You can get your sensor voltage form the yel-wht on the TPS plug. Make aure you check your TPS voltage after.
#2014
Re: (kurtywompus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurtywompus »</TD></TR><TR><TD CLASS="quote">Sensor voltage - RED/WHT - goes to D19 or D20
so there is a place i can tap into the harness some where for this one.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">You can get your sensor voltage form the yel-wht on the TPS plug. Make aure you check your TPS voltage after.</TD></TR></TABLE>
#2016
I need some help??????
I swapped the h22 in my 94 eg civic everything runs fine but i have 2 problems and the one that bothers me the most is that i cant get my rpms past 6500 it looks like 6700 rpms but its bound to be off. i had the stock p28 then had that chipped with the jdmshit program same thing tried the p13 ecu but runs kinda crappy between 2000 to 3000 rpms but same 6500 cutoff tried a chipped P0A ecu same thing. it seems like a fuel s oi change fuel pump check timing valve clearance fuel pressure regulator im stumped and dont know what to do i dont get any check engine lights which brings me to my next problem after hitting vtec if i were to rev that high after i come to an idle the check engine light comes on usually on fifth and fourth gear i have the prelude si tranny ohh an vtec always kicks in at 4000 with all the ecus. i created a vtec light by splicing the vtec silinoid wire and connecting it to a light on the dash also my speedometer is like 10 mph off around 80 mph
#2017
Re: I need some help?????? (acex)
Guys, please help me with my swap. I put JDM H22A from 4th gen Prelude to my EG-4 JDM Civic, but can't find axles and midshaft. in our junkyard i can find a lot of JDM f20b f22a,b, ZC, but can't find F20A midshaft. the same situation with axles. So my question, anyone knows can i apply another part, like midshaft from f22b, and axles from b20b from cr-v.
PS sorry for bad english
#2018
Re: I need some help?????? (4rest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rest »</TD></TR><TR><TD CLASS="quote">Guys, please help me with my swap. I put JDM H22A from 4th gen Prelude to my EG-4 JDM Civic, but can't find axles and midshaft. in our junkyard i can find a lot of JDM f20b f22a,b, ZC, but can't find F20A midshaft. the same situation with axles. So my question, anyone knows can i apply another part, like midshaft from f22b, and axles from b20b from cr-v.
PS sorry for bad english</TD></TR></TABLE>
you can use the intermediate shafts from 90-97 accords. and for axles use 90-93 integra axles.
#2019
Re: I need some help?????? (everlasting1832)
They are all the same? (i mean intermediate shafts (between f20a f20b f22a f22b g20a) and axles(between d16a b16a b18b zc b20a b20b) ). i saw integras with d16a or zc, will these axles fit?
#2020
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rest »</TD></TR><TR><TD CLASS="quote">They are all the same? (i mean intermediate shafts (between f20a f20b f22a f22b g20a) and axles(between d16a b16a b18b zc b20a b20b) ). i saw integras with d16a or zc, will these axles fit?</TD></TR></TABLE>
read the first page of this thread. d16a are zc from way back then. i never saw b20a and b20bs stock in integra. only b series i saw in those gen integra's were the b18a's, b17, and b16s in the xsi.
#2021
thanks for the info turbogixxer, I will go over all the wires, but i just finished wiring it and im pretty sure i have done it the way you posted it.
Besides its not throwing codes anymore so i would assume that means its wired right?
Thats why i was thinking it might be a leak, or that the egr might be gunked up from sitting so long on the motor without being hooked up. In that case could i run some sea foam through it? As of yet i cant get it off the manifold to clean it and check the diaphram, going to have to use a oxy acetelene torch to heat the studs.
Skunked, i told you like 5 months ago you live right next to me! for a little while i thought you lived down the street.
thanks everlast, im gonna recheck every thing for leaks with the car running.
***i finally got the egr off, the diaphram is fine and there was only a little carbon buildup which i took care of, gonna put it back on with a new gasket and see what else i can find that might be causing it
Modified by H22poweredNoob at 12:29 AM 1/28/2006
