[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
#751
Re: (double)
yes, it's possible. I would try cleaning it with some brake cleaner.
If the wiring is all good and right, and the EGR valve is clean, it could be a faulty vavle, or the solenoid also might be bad.
#752
Re: (poison)
How many of u guys got LSD trannies?i think h22 is the way im gonna go, time to shop for a good priced motor. Anyone know a site with step by step install inst. MAin thing im concerned with is the harness, i plan on getting the car Bar;ed at the referee before Nov.
Ps. I got a b16 in the car right now (1995 civic) so i got most of the wiring in.
Modified by sleepingeg6 at 8:54 AM 6/25/2004
#753
Re: (sleepingeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingeg6 »</TD></TR><TR><TD CLASS="quote">i think h22 is the way im gonna go, time to shop for a good priced motor. Anyone know a site with step by step install inst. MAin thing im concerned with is the harness, i plan on getting the car Bar;ed at the referee before Nov. </TD></TR></TABLE>
heres a good h22:
https://honda-tech.com/zerothread?id=894169
step by step.? go to page 1 of this thread. im sure u've seen it though.
heres a good h22:
#756
Re: (turbogixxer)
i am having problems finding pics of the rear mount setup. I have hte hasport 6 piece setup and want to see how the rear mount bolts up.. apparently i need a prelude rear bracket.. Will and accord one work?
#757
Re: (HavokB18)
ok i have been looking all over for someone to help me with this i am putting an h23 vtec in a del sol and i am not using the AC system and i really need to know what underdrive pulley to use to accomidate for the extra slack can someone please help me thanks alot e male we @ Princesveg23@aol.com thanks again
#758
Re: (poison)
has anyone had a problem with the map sensor when putting obd 1 in obd2. my engine map is 2 wire and my harnness is 3 wire. engine wont go past two grand w/o it. it drives decent, but wont go past 2k rpm. woo hoo fun
#760
I need to know what parts to use to retain power steering and ac in my 92 civic si with a h22 swap. please be specific, also, i'm looking to go turbo, any recommended parts or kits considering less room due to ac and ps. whats axles should i go with if using the hcp kit and boosting, really looking to put serious #'s to the wheels, like 500 and up.
#761
I know it is possible to go turbo with power steering and ac, i've seen it done in person i just need some tips and advice on what to use, any help is greatky appreciated.
#762
Re: (TriniTech)
I'm not sure what turbo manifold on the market is out there that will clear PS and A/C, but I'm sure there is.
If not, you might need to have a custom turbo manifold.
#765
Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">I'm not sure what turbo manifold on the market is out there that will clear PS and A/C, but I'm sure there is.
If not, you might need to have a custom turbo manifold.</TD></TR></TABLE>
here u go: (i think this is my favorite yet)
these 2 pix are on a B series. but they are available for the H as well.
oh ya. its all made by HyTech. i think cost is like $1500. not sure if thats with the dp or not.
#766
damn , $1500 thats pricey, i wish i could see how it sits with the h22, i got a fluidyne radiator, not real anxious to hack into it to relocate coolant neck, thanx though, i'll look into it. If anyone esle knows about one lemme know.
#768
Re: (hondaZvic)
I need help with this god awful code 12 (EGR) I have been getting. I checked all the wiring I have continuity to all wires.
<U>EGR control solenoid</U>
A25 power
A11 ecu trigger
<U>EGR valve</U>
A25 power
D12 ecu trigger
D22 ground
All vacuum lines are correct the EGR port on the intake manifold is recently cleaned.
I have tested the EGR valve by applying 8 in Hg of vacuum. The valve holds vacuum and the car stalls when the vacuum is applied. I have tried road testing the car with a vacuum pump/ gauge attached to the lower port on the egr control solenoid (#16 hose) the one that goes to the EGR valve. The solenoid works and sends vacuum over to the EGR valve. I am reading around 6 in Hg of vacuum while doing this road test. I have directly jumped the egr control solenoid with power from the battery on one lead and a ground on the other. With all vacuum lines connected. During this test I can physically see the EGR valve lift when I ground the solenoid. I am reading around 6 in Hg vacuum during this test. I have even tested the CVC valve it seems to be ok also matching its recomended vacuum in the Helms manual. The only thing I can think of is one or both the EGR control solenoid and EGR valve itself are bad. The EGR control solenoid is suppose to have around 8 in Hg of vacuum. During all the test I tried I only noticed around 6 in Hg of vacuum. I tested a friends car old Accord with EGR no codes his car also only read about 6 in Hg of vacuum. Someone give me so new ideas I need help. My registration is past due and I need to take this thing to the referee CA smog rules suck.
A25 power
A11 ecu trigger
<U>EGR valve</U>
A25 power
D12 ecu trigger
D22 ground
#770
Re: (turbogixxer)
I am leaning towards the solenoid myself. The only thing that is steering me away is I borrowed a solenoid from someone that says they have no codes. I am still throwing a code with there solenoid. I have 3 egr valves all used not sure of the condition they all do the same thing when put in. Also 2 egr control solenoids I have tried both. I really don't want to buy this stuff new since I am only going to use it for smog once every 2 years. LMK if you find that flow chart. If someone has egr hooked up in there eg and has access to a vacuum pump gauge IM me I want to see if you can gather some info for me. It should only take about 10 min tops to do.
#771
h22 wiring need help
ok i don't know if any one has asked these questions but i really need to know im
going to be putting my motor in soon and i have a DOHC Del Sol shell what do i
have to do to the Del Sol wiring to work with the H22 motor wiring harness and
p13 ecu
thanks alot of the help
p13 ecu
#773
Re: where to get it (Jdmdelsolguy2004)
i went to start up my h22 del sol and i tried to fire it up and its not sparking. first i tried the h23 dizzy w/external coil wired it up and still not getting spark. so i checked all my fuses.. all good. then i started testing wires for power. well all are getting power. so i take off that dizzy and i threw on the del sol dizzy and just held there cause the bolt pattern is different and still nothing and i had power to it that time also. i dont know what is going on. could it be like a ground or something or what i am running out of ideas some body help
#774
Re: where to get it (jdmh22lude)
i could be one of the igniter inside of the dizzy thins happened to my girlfriends car and we changed it with a whole dizzy and it worked fine
#775
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22lude »</TD></TR><TR><TD CLASS="quote">i went to start up my h22 del sol and i tried to fire it up and its not sparking. first i tried the h23 dizzy w/external coil wired it up and still not getting spark. so i checked all my fuses.. all good. then i started testing wires for power. well all are getting power. so i take off that dizzy and i threw on the del sol dizzy and just held there cause the bolt pattern is different and still nothing and i had power to it that time also. i dont know what is going on. could it be like a ground or something or what i am running out of ideas some body help</TD></TR></TABLE>
Your thermostat ground hooked up?
