K24 - differences between Accord, TSX, and CRV?!
Old 12-26-2004, 09:50 PM
opto_isolator's Avatar
Default K24 - differences between Accord, TSX, and CRV?!
Ok, WTF is Honda trying to pull here....
As far as I am aware - which may not be a lot - there are not major differences between the accord K24, CRV K24 and TSX K24 - are there?!
I know that the intake manifolds are different - but wtf. Check this out:
CRV short block MSRP from Hondaautomotiveparts.com: $3500
TSX short block MSRP from Acuraautomotiveparts.org: around $3500
BUT
Accord K24 short block MSRP from Hondaautomotiveparts: $1500!!!
Is there something that I am missing or what?!?
If the blocks are pretty much the same, why the hell are the prices so much different? I am thinking of going a K20 / K24 hybrid route in the future and am looking into prices, parts, etc....But well, anyone?
Old 12-26-2004, 10:49 PM
pb16b's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (opto_isolator)
...interesting.
Old 12-27-2004, 06:37 AM
nickzed20's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (pb16b)
i know, its pretty stupid
and you know that its not just the internals, its the block itself... if you go look at the prices for the blocks alone, that of the CRV is insanely more expensive then the accord one, which makes no sense to me.
Old 12-27-2004, 07:50 AM
Default Re: K24 - differences between Accord, TSX, and CRV?! (nickzed20)
Well, that's why I asked - I wonder if anyone has tried an accord K24 and see if their the same or what?
If they are, thats a lot of money saved right there (plus a lot more options opened up).
Old 12-27-2004, 08:04 AM
fabworxs's Avatar
seriouly...thats crazy.
Old 12-27-2004, 08:29 AM
nickzed20's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (fabworxs)
between the blocks themselves, i dont think there is a difference between the CRV and the Accord/Element (both same price and same thing), if anyone has a CRV or TSX block, take detailed pics and i will compare them to my Accord K24 block!
Old 12-27-2004, 09:23 AM
MonkeyManStunna's Avatar
i was thinking the same thing i was about to purchase the k24a4 (accord) block on ebay but i didn't know if they were any different from the other k24 blocks. i reduing my whole bottom end anyways so i might as well get the cheaper one.
Old 12-27-2004, 10:49 AM
Crazy Honda Guy
Deetz's Avatar
I checked this stuff out about a year ago....the crx, element, and accord all seem to be the same bottom end. The tsx has a slightly better counterbalanced crank making it better for high rpm.
Old 12-27-2004, 11:12 AM
AllMTRWH0R3's Avatar
Default Re: (Deetz)
^^^^^^ but if it;s lighter it like the whole itr crank vs ls crank threories here. goos stuff, but people are selling the blocks for around 450.
Old 12-28-2004, 06:56 AM
Nikos's Avatar
Default Re: (allmtrwhore2)
they do have differences.
What do these shortblocks come with? crank? rod/pistons? How coplete are they?
Roughly the TSX one is more similar to the accord one. The CRV one is different on top.
You see, the CRV one doesn't have all the EGR crap on top. There is no EGR on the TSX. Parts are there but the ports are blocked off. The water take off point which is integral to the TSX intake manifold is on a different position. You can bolt on a CRV and probably an Accord throttle body.
You can machine the accord block to make it accept a type r manifold for example. The crv block will accept one with no mods.
Old 12-28-2004, 07:02 AM
Nikos's Avatar
Default Re: (Nikos)
taken from honda tuning magazine
Old 12-28-2004, 09:00 AM
TurboC53_4g63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opto_isolator &raquo;</TD></TR><TR><TD CLASS="quote">
BUT
Probably has something to do with Accords being hella cheaper new then the other 2 cars.Meaning more Accords to wreck/total out.
Old 12-28-2004, 04:31 PM
fabworxs's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (TurboC53_4g63T)
So, if I had an RSX swap and wanted to go with the K24 short block which one should I get?
Old 12-28-2004, 04:32 PM
HT White Ops
ShaunRR's Avatar
Hmmm.
Old 12-28-2004, 04:57 PM
brian g's Avatar
CRV ...$3500
TSX ...$3500
Accord ...$1500!!!
It has mostly to do with availability. The Accords are made in the US the others are not. The Accords are made by the hundreds of thousands anually too.
brian g
Old 12-28-2004, 05:10 PM
Default Re: K24 - differences between Accord, TSX, and CRV?! (brian g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">
brian g</TD></TR></TABLE>
Hail to the king baby!
In your experience, would their be any true merit with going with an accord k24 vs a CRV or Element K24? Is it true about the internals being beefier in the TSX K24 - OR are they pretty much a horse a piece? If so - the opportunity to create a frankenstein has just become much greater!
Old 12-28-2004, 08:26 PM
brian g's Avatar
In your experience, would their be any true merit with going with an accord k24 vs a CRV or Element K24? Is it true about the internals being beefier in the TSX K24 - OR are they pretty much a horse a piece? If so - the opportunity to create a frankenstein has just become much greater!</TD></TR></TABLE>
The Accord and Element blocks are identical, also you can't bolt an RSX head to them without changing the pistons. There will be interference.
The CRV block is compatible with the RSX head, but if you rev it too high you will get valve to piston contact.
The TSX block has the goodies. I haven't compared the cranks, but the rods are definitely beefier. There should be decent valve clearance with an RSX head too.
If your going to leave the engine stock, get the TSX engine. You can buy compete engines from junk yards for $2K. You can use the stock head until you can buy an RSX head. In the next two months we are coming out with an adapter so that you will be able to bolt the RSX manifold (or supercharger) on to the TSX head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">taken from honda tuning magazine
About this, we've learned that this is not the case, the TSX head doesn't use an EGR, but it is ported for one.
brian g
Edited , thanks Nikos
Modified by brian g at 4:17 PM 12/29/2004
Old 12-29-2004, 04:03 AM
Nikos's Avatar
The TSX head has the goodies. I haven't compared the cranks, but the rods are definitely beefier. There should be decent valve clearance with an RSX head too.
I think you meant to say TSX block.
Old 12-29-2004, 04:40 AM
6SPD_EK's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (Nikos)
correct me if I am wrong but the K24a1 (CRV) has a CR of 9.6:1 while k24a4 (accord/element) has a CR of 9.7:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabworxs &raquo;</TD></TR><TR><TD CLASS="quote">So, if I had an RSX swap and wanted to go with the K24 short block which one should I get?</TD></TR></TABLE>
go with K24a2 (TSX) Hotwheelz did this in his RSX...dyno'd ~215whp & 180 lb/ft on a dyno jet with K-pro (not fully tuned - i believe) - if not go with K24a1 (CRV) so you don't have to swap out the pistons like you would with a K24a4 (accord/element) - like brian g said
Old 12-29-2004, 07:20 AM
brian g's Avatar
Default Re: K24 - differences between Accord, TSX, and CRV?! (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I am wrong but the K24a1 (CRV) has a CR of 9.6:1 while k24a4 (accord/element) has a CR of 9.7:1
Yes and the combustion chambers and piston domes are significantly different, that's why you can't bolt an RSX head on a K24A4 block.
brian g
Old 01-03-2005, 11:11 AM
JDMzEaL18's Avatar
k well i found an article here ....i think this should help
http://www.sportcompactcarweb....ybrid/
Modified by JDMzEaL18 at 12:27 PM 1/3/2005
Old 01-03-2005, 05:17 PM
brian g's Avatar
Default Re: (JDMzEaL18)
Look, that's me in those pictures! Whoo hoo, I'm a legend in my own mind.
brian g
Old 01-03-2005, 05:39 PM
HT White Ops
ShaunRR's Avatar
Default Re: (brian g)
What is up with all the big guys in the import world having shaved heads?
Is that the secret to making it in this industry? I'll be right back, gotta go buy some razors.
Old 01-03-2005, 06:27 PM
locash's Avatar
Default Re: (rochesterricer)
You must have looked at the wrong picture, as Brian has the fluffy gray hair, and the cylinder heads were not shaved either..
Old 01-03-2005, 06:41 PM
JDMzEaL18's Avatar
hey just wondering
"K-series hybrid hood " ....any luck with this .... the whole power-steering issue
Quick Reply: K24 - differences between Accord, TSX, and CRV?!
