Honda S2000 Honda S2000
Serious help My car is in horrible condition got a P0325 code
Old 03-15-2007, 02:36 PM
  #26
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (FR-MOB: Jerk)
not me.. OP....
Old 03-15-2007, 02:43 PM
  #27
Vice President/CEO
kKdARIAN's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (S@nt0s)
holy crap man... sounds like your S has seen better days..
let us know what you find out... your a very forgiving person.
Old 03-15-2007, 04:02 PM
  #28
TheDancingPill's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (kKdARIAN)
Same here man hope your s2k will be drivable soon
Old 03-15-2007, 07:32 PM
  #29
S2K Luver's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (TheDancingPill)
I think my car is having more of electrical problems.
Because the speedometer doesnt work neither does the VTEC. The RPM gauge works thoughs. Also my VTEC isnt working and it hasnt thrown codes for any of the other things. It only threw a knock sensor code. I think its having electrical problems. Its acting like a VDUB and not a Honda.
I'm not forgiving but if I focus on the bad im just going to feel horrible, be upset and that wont fix anything at all. I wanna move on and fix it.
Old 03-15-2007, 10:27 PM
  #30
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (S2K Luver)
you have a knock code???? well thats another reason since the ECU sees a knock it will pretty much go into limb mode.....
Old 03-15-2007, 10:31 PM
  #31
S2K Luver's Avatar
It wont cause it to mess up my eps and speedometer.
I can see my VTEC but everything else should work.
Old 03-16-2007, 12:16 AM
  #32
* B A N N E D *
Mr. Projekt's Avatar
EPS has a fail-safe circuit that resets itself. Check the 70AMP fuse in the driver side underhood fuse box as well.
As for the TDC sensor, it's supposed to be covered in oil, unless you're talking about the plug-to-harness connection itself.
The VSS is on the passenger side of your tranny. See if that's covered in oil as well.
Driving without the oil cap off would affect the oil pressure. No VTEC. You never mentioned if you refilled the oil to capacity or not.
Old 03-16-2007, 10:24 AM
  #33
S2K Luver's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">EPS has a fail-safe circuit that resets itself. Check the 70AMP fuse in the driver side underhood fuse box as well.
Driving without the oil cap off would affect the oil pressure. No VTEC. You never mentioned if you refilled the oil to capacity or not.</TD></TR></TABLE>
I refiled it It.
Where would the clip be in the engine bay for VSS
Old 03-16-2007, 10:29 AM
  #34
* B A N N E D *
The VSS clip runs directly off the engine bay harness to the passenger side of your tranny.
Old 03-16-2007, 10:59 AM
  #35
ReddotsS2K's Avatar
this is why i do everything to my car myself. if someone messed up that ba di would have to murder them. good luck and i hope you get it back up to normal.
Old 03-16-2007, 11:33 AM
  #36
WowOzYouRock's Avatar
Default Re: Serious help My car is in horrible condition got a P0325 code (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">this is why i do everything to my car myself. if someone messed up that ba di would have to murder them. good luck and i hope you get it back up to normal. </TD></TR></TABLE>
e-thug stunnaz!!! rofl .... a guy who has AIMs SN of "youloveit51" can kill!!? hahahah puhlezzz
Old 03-16-2007, 11:36 AM
  #37
ReddotsS2K's Avatar
haha im 17 stunna, gotta keep it pimpin for the women cuz the bitches love it
Old 03-18-2007, 08:17 PM
  #38
S2K Luver's Avatar
I think my EPS/Speed Sensor have bad grounding
Old 03-18-2007, 08:49 PM
  #39
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K Luver &raquo;</TD></TR><TR><TD CLASS="quote">
My vtec doesnt work and speedometer doesnt work. I got a Knock Sensor Circuit Malfunction code. My idle is way off it goes from 500-1000 RPM and ranges. The motor doesnt make any knocking noises though and the oil pan doesnt have any metal. I have a magnetic oil plug. My TCD sensor also has oil all over it.
A mechanic worked on my car and returned it to me. Forgot to put the oil cap on and I drove it for 3 hours. I got oil all over the harness but the car was working fine. All I did was change the oil on it right away after that and called the mechanic to give me my oil cap. I think the oil might of gotten all over the harness and over time caused it to be bad?????
I dont see how all my sensors would be bad? It seems like they are though? The car wasnt that bad until I left it sitting for about 4 months it seemed to have just gotten worse. </TD></TR></TABLE>
take your car to a freakin auto zone brother.
they can tell you almost exactly what is wrong with your car, and it wont cost you a dime
Old 03-18-2007, 09:02 PM
  #40
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K Luver &raquo;</TD></TR><TR><TD CLASS="quote">I think my EPS/Speed Sensor have bad grounding</TD></TR></TABLE>
EPS has it's own ground, VSS does not.
plantinseeds
06-14-2018 05:46 AM
ryan21x5
07-31-2014 02:38 PM
Keith_B
06-22-2009 01:14 PM
stareatsun
03-31-2006 03:28 PM
Mugen1320
11-04-2005 12:38 AM
Quick Reply: Serious help My car is in horrible condition got a P0325 code
