Honda S2000 Honda S2000
Air/Fuel gauge install!
Old 04-14-2005, 07:43 PM
nick32's Avatar
Default Air/Fuel gauge install!
Im having trouble hooking my air fuel gauge up in my S.
i have the power and ground connectred correctly but i dont know where exactly the violet wire goes. It says it goes to the signal wire on the o2 sensor. What wire is that and where is the easyest place to get to if to hook the violet wire up to it?
thanks for any help given
nick
Old 04-14-2005, 08:48 PM
Francesco's Avatar
Default Re: Air/Fuel gauge install! (nick32)
if im not mistaken you can tap that kind of A/f gauge into the fuse box...their should be a signal that runs into that...if not you have to tap the o2 sensor before the cat...
i think the 02 has 2 wires, black and white...black should be ground and white should be hot.
Old 04-15-2005, 07:56 AM
nick32's Avatar
anyone have a pic of where the tap is in the fuse box? cause i dont really wanna run the wire all the way down to the cat, and other than that i dont know where to hook it up. and i need to get this gauge working.
thanks
nick
Old 04-15-2005, 08:22 AM
WowOzYouRock's Avatar
Default Re: (nick32)
tap it to the white wring in yer O2 sensor
Old 04-15-2005, 08:32 AM
nick32's Avatar
so i should run it all the way down to underneath the car?
the sensor in the header or the one in the cat?
Old 04-15-2005, 09:21 AM
devnull's Avatar
check your post on s2ki. I answered it.
Old 04-15-2005, 09:36 AM
MrITR#0168's Avatar
run it to your ECU
Old 04-15-2005, 09:39 AM
Default Re: Air/Fuel gauge install! (JDMhatchie128)
i have told that you get better signal and more accurate if you tap it close to the O2 sensor ...
Old 04-15-2005, 11:53 AM
SuzukaBlueAP2's Avatar
Default Re: (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy &raquo;</TD></TR><TR><TD CLASS="quote">check your post on s2ki. I answered it.</TD></TR></TABLE>
Why not share with the rest of us?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMhatchie128 &raquo;</TD></TR><TR><TD CLASS="quote">run it to your ECU </TD></TR></TABLE>
That's what I did with the A/F gauge in my old Integra.
Old 04-15-2005, 01:30 PM
nick32's Avatar
how do i get to the ECU in the S? is is under the passanger side dash?
anyone know exactly what wire to tap into? i hear it was 16th wire in the second plug? is that accurate..its a white wire.
Old 04-15-2005, 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick32 &raquo;</TD></TR><TR><TD CLASS="quote">how do i get to the ECU in the S? is is under the passenger side dash?
anyone know exactly what wire to tap into? i hear it was 16th wire in the second plug? is that accurate..its a white wire.</TD></TR></TABLE>
driver side kick panel... and look for ecu schematic its should tells you the O2 wire
Old 04-16-2005, 04:57 AM
nick32's Avatar
yay, i got it hooked up.. its pretty coo. hehe
thanks for the help guys!
Old 04-16-2005, 08:26 AM
JDM_AP1's Avatar
so did you hook it up to the ECU?
Old 04-17-2005, 12:06 PM
nick32's Avatar
yup hooked it up right to the ECU, wire c16, the solid white one.
works good, seems like theres a fine signal.
Old 04-17-2005, 04:44 PM
Good deal. Glad it is working for you!
krysted9354
01-24-2009 06:23 PM
ma_rio44
07-03-2007 08:27 AM
JDMhondalude22
10-26-2006 06:14 AM
URtaxes
10-09-2005 06:32 PM
integra0260
07-28-2001 03:35 PM
Quick Reply: Air/Fuel gauge install!
