Fuel pressure regulator soleoind question?
Old 11-26-2010, 06:03 PM
nemesis25's Avatar
Default Fuel pressure regulator soleoind question?
I'd like to know, how to hook the fuel pressure regulator solenoid, on a JDM H22? Someone, mentioned I could remove it and run a vaccumm hose to the Intake Manifold. But I don't want to do that, so as not to have a CEL for it. So, my question does anyone know how to hook this unit up to a JDM ECU? Attached is a pic of it.
http://i215.photobucket.com/albums/c...e/DSC00907.jpg
Thanks.
Old 11-26-2010, 08:39 PM
92civlude's Avatar
Default Re: Fuel pressure regulator soleoind question?
Run The FPR directly to intake manifold vacuum. Toss the solenoid. No CEL will result.
Old 11-26-2010, 09:21 PM
BigBlock22's Avatar
i was just going to send you a vacuum hose diagram but i can tell you that purge solenoid is not for the FPR. its for your EVAP canister
Old 11-27-2010, 03:08 PM
nemesis25's Avatar
I got it, the yel/black wire from the fuel pressure regulator solenoid goes to the Evap purge solenoid(yel/black) and the other wire goes to A10.
akcapr
01-25-2011 02:59 PM
champLSinteg
11-08-2006 12:53 PM
ophdehEEzY
04-15-2003 07:40 PM
NZ Vtec Weapon
02-24-2003 07:56 AM
lilxvtecxpwr
12-21-2002 10:28 PM
Quick Reply: Fuel pressure regulator soleoind question?
